Full Version: How do you change the background for the login screen?
I love this skin and its ability to be customized, however, I can't figure out how to change the default background for the login screen. It is just too bright and makes it difficult to see the text when logging in. This is the same background you see when you go into settings, changing the theme does not seem to work.
Any ideas?
