Full Version: XBMC 14 Build August 18 For OUYA - Last Build With Working Controllers
Just in case no one else noticed..
August 18th build of XBMC 14 is the last build with working controllers for OUYA.
After that build only the mouse pad works. Whoops! Wink
Thanks,
Will
Some defaults have changed for nightly builds. I think you can get around it by just re-enabling joystick support and/or re-adding a keymap. Not sure.
Yes, i have asked here for a solution http://forum.xbmc.org/showthread.php?tid=202687, still today the controller don't work, but i think the great Koying is working on it.
Ah, excellent. Hopefully it will be working again soon.
Yep. Should be good again as of today's nightly.
Confirmed, working again.Smile
Thanks a ton!
