2014-08-31, 20:06
2014-08-31, 20:12
Can you elaborate on "video stutter". Is this a kind of micro stutter we observe as a result of a mismatch of refresh rate to fps or something more noticeable? I guess the latter, right?
13:47:12 T:139832181384960 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
13:47:18 T:139833904998336 WARNING: Previous line repeats 31 times.
Something seems to block the render thread.
We will see more in the 14.x log.
2014-08-31, 20:39
Back to feeling dumb again. I followed the WIKI that the Helix page sent me to, 1.3 installing a beta/unstable version, and all I got was 13.2 again. What am I missing?
Video stutter - the picture noticeably freezes and then jumps to keep up.
2014-08-31, 20:53
Try this ppa:
sudo apt-add-repository ppa:wsnipex/xbmc-fernetmenta-master
sudo apt-get update
sudo apt-get install xbmc xbmc-bin
From this how-to: http://forum.xbmc.org/showthread.php?tid=174854
sudo apt-get update
2014-08-31, 20:55
Thanks. Will do
2014-08-31, 21:16
No progress. Helix loaded fine, set up the sync playback and method. for some reason audio passthrough did not show up.
new file:
http://xbmclogs.com/show.php?id=282997
I appreciate all your efforts!
new file:
2014-08-31, 21:55
I would try to update the NVidia diver to the most recent version next.
2014-08-31, 22:36
Passthrough won't show up cause your pulseaudio is configured to do 6 channel PCM. Check our wiki in how to do that correctly :-)
2014-08-31, 23:43
I have the latest NVIDIA driver available through "Additional Drivers". I will go to NVIDIA direct for a more current update.
When I updated to Gotham, i also updated Linux from 12.04 to 14.04. Could there be any cause and effect there? I had no problems before.
I did check VLC player and it works fine, no stutter at all. Not sure that means anything. I did not mess with the passthrough since you want to disable it anyway.
2014-09-01, 08:37
You can't compare to VLC in this case because VLC does not render via OpenGL. According to the change logs NVidia has fixed quite a few OpenGL bugs in recent versions of their drivers.
2014-09-01, 15:32
Checked the NVIDIA site, and while there is a driver available, it is beyond my ability to install. I cannot get past the stop xserver step. I go to a black screen with a flashing cursor that does not allow input.
Earlier versions of the NVIDIA drivers had no problems. I tried the version I had installed before the upgrade, and the problem persists.
I am now headed for the roll back mode. My next step seems to be to purge everything and start fresh. I am hoping it is an install bug of some type.
This unit is primarily a HTPC. Would you recommend a minimal Linux install over a full Linux install?
2014-09-01, 15:35
google x-swat ppa you should not install the Linux driver from nvidia site, ideally the distro packaged drivers are recommended even by nvidia.
2014-09-01, 15:37
You can install vie ppa like this one: https://launchpad.net/~mamarley/+archive/ubuntu/nvidia
2014-09-02, 02:48
Finally figured out how to post the xrandr file, if you still need it.
https://www.dropbox.com/s/551o8sdxudi6xr...randr?dl=0
I updated to the most recent driver. No change.
I am game for anything at this point.
What if I removed pulseaudio? I do not need it for anything.
2014-09-02, 04:26
the best way to post a log from ubuntu is to install pastebinit.
Now pastebinit can take a file as an argument like
or you can pipe the output of another command to it:
Either way the url of the paste is left on the commandline for you to copy and paste in here.
sudo apt-get install pastebinit
pastebinit ~/.xbmc/temp/xbmc.log
xrandr|pastebinit
