Trying to get movie set info and the discs available for collection. I am running gotham and have correct skin. I also have extended info script but am not getting the set information or the discs showing on right list or low list. am i missing something?
Have you tried an older version of ExtendedInfo? At least in MQ5, the new version from Phil's git doesn't work. The skin needs to be updated to support the newer ExtendedInfo. Try 0.0.6 (I think that's the version):
https://github.com/azraelomega/script.extendedinfo
Hmm removed version I had and installed this but doesn't seem like did anything. Do I have to run anything?
The only thing I remember doing is restarting the computer. Then movie set info worked. I can't say for sure that the same fix will work for Ace, but thought it might be worth a try since the skins share some code and a common developer.
