(2014-09-18, 07:13)nickr Wrote: [ -> ]So you press 'T' when you are watching TV and what happens? A debug log (wiki) might also help.
I'll have to do the debug log later, and I don't know what "T" is supposed to do, because I have OpenELEC running on a Pi, controlled by the TV remote. My experience, in detail, is as follows:
- Play recording
- Press OK key (at centre of up-down-left-right keys) to bring up menu at bottom of screen
- navigate to subtitles button at bottom of screen - shows only "download"
- navigate further right to sound button (the little speaker) and select "enable subtitles". Although enabled, you can't select a subtitle below in the same dialog — the selection is set to "none" and the option is inactive.
- no subtitles are playing
- navigate back to subtitles button, which now contains further items, including (the exact name may be a bit different - this is from memory) "activate subtitles", which is already on, and "browse for subtitles".
- If you select "browse", you get a list of shows (episodes of the same show that have been recorded, I think) with the show being watched already highlighted.
- If you click OK in this dialog, you return to the video, which plays for a second or two, without any subtitles.
- The Pi freezes up so hard at this point that (although the frozen frame is still on the screen), there is no response to button presses and an SSH session can't even be initiated. Only option is to unplug power.
Let me add - if it was supposed to work once I enabled subtitles in the sound dialog, I feel that this procedure is not only cumbersome, but unintuitive.
