Full Version: AEON MQ FREEZE (SAMSUNG TAB)
hi all, as you can probably notice in new to this forum and this is my very first postBig Grin l am also new to XBMC and to be honest blown away at what can be achieved with this software .
I have been looking at various videos on you tube on how to install and configure addons and l came .across this Aeon nox Skin MQ5 .
My problem is that when I change my skin to Aeon MQ5 on my Samsung note tab its like it Freezes , l cannot scroll across to different tabs and basically am Stuck on the start screen with the blonde chick on itBig Grin
/ cannot perform any task and basically had to wipe all data and loose everything including add ons and start again !
l ha✓e tried this 3 times but ended with the Same result .
Any tips on what i might be doing wrong.?
thanks .-.
I think it's an issue with the skin.
http://forum.xbmc.org/showthread.php?tid=199729
