2014-09-03, 21:43
Hello!
I have installed Webgrab+. I have the installation on Ubuntu 14.04 to have EPG data in TVHeadend (HTS Tvheadend 3.4.28~geb79aee~trusty).
The installation was OK following the guide here: http://webgrabplus.com/documentation/int.../tvheadend
I installed the most recent files (including the patch). Everything worked fine (after some troubles - but this was due to my limited Linux knowledgeBlush) and now I was able to test the grab file in /usr/bin and it works. The guide.xml file seemed to be properly built. Now I was checking the TVHeadend settings and I was able see the tv_grab_file (the wg++ one) in the configuration (dropdown and selected it) in TVHeadend.
After selection of that and save changes I cannot see or select the EPG channels in the channel view in TVHeadend (it worked with mc2xml). Huh
I have no clue what I could have missed. The direction I am going now is if any permissions are not correct. do you have had a similar issue so far?
One fact I was doing is that I installed the files and modified them remotely on my MAC. So config files edited with notepad and copied back with FTP. the command line commands I made with an SSH connection to my linux machine. the fact I mean is that most of the files are now written with the root user. could this be a problem?
Or do I need to place the /wg++ folder inside the root folder of HTS? HuhConfused
Any help would be appreciated! Nod
thanks
/krijeck
PS: sorry for posting this a second time but I thought an own thread would be justified as I am already really desperate.
thanks
/krijeck
