I've tried both the latest stable Gotham release and SPMC, but they are both experiencing this issue. When I start up a playlist, it only makes it through 2 or 3 videos before crashing the program and taking me back to Fire TV Home. Anyone else experiencing this issue or have a fix? Thanks!
Yes turn off mediacodec. Use libstagefright. If certain mpg2 files don't work use software decoding through advancedsettings.xml.
(2014-09-07, 06:15)jjhtpc Wrote: [ -> ]Yes turn off mediacodec. Use libstagefright. If certain mpg2 files don't work use software decoding through advancedsettings.xml.
That fixed it! Thank you!
I have this exact same issue when I use the Karaoke, would this fix work for this
works like a charm. thanks.
