Full Version: Amber now updated to support Kodi 14.0\Helix
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
Reinstalled Amber today and it is Fantastic as it has always been... thanks...
one shameless request/help, is it possible to set the type of artwork in the "list" view for TV Shows?
Let me explain, for some tvshows the "Poster" is used and for some other the "Banner" is used.
The banner doens't "fill" the screen as well as the "poster" does.
So I woudl like to force all thvshows to have posters displayed. (or at least choose what type of artwork to use...)
Is it possible?
Thanks a lot
M
(2015-01-06, 18:43)mcarni Wrote: [ -> ]Let me explain, for some tvshows the "Poster" is used and for some other the "Banner" is used.
Sounds like your KODI has a problem with artwork cache or something. Refetch artwork for problematic TV Shows and then choose a view that suits you more. If you get banners in poster view or vice versa something is wrong with your install and this can't be solved in a skin.
For those who were getting the "structure is incorrect" problem on FireTV. You need to rename both the file AND the main folder within.
skin.amber.zip = skin.amber-2.x.x.zip
skin.amber (folder) = skin.amber-2.x.x (folder)
Sorry Pecinko, my mistake, I cleaned the cache, redownloaded the artowrk and all was sorted.
thanks a lot
m
Hi all with install problems.
I am running amazon fire tv and kodi 14.
We're getting all kinds of errors installing
because of file name. My setup would not install with - in the file name.
Renamed file to skin.amber.2.0.2.zip for the 2.0.2 version and all installed perfect.
I have not unzipped an modified folders only filename
please try it
worked for me
(2015-01-06, 12:56)pecinko Wrote: [ -> ]Version 2.0.3 is up!
https://github.com/pecinko/skin.amber/ar...master.zip
Changes are listed here:
https://github.com/pecinko/skin.amber/commits/master
Still would like to get some feedback about PVR. Many thanks to gismo112 who provided latest PVR fixes on GitHub. Nice teamwork guys Smile
Thanks Pecino Smile
Teamwork is what help us all.
Greets Gismo
(2015-01-06, 15:17)mortenls Wrote: [ -> ]
(2015-01-05, 21:51)noap_ Wrote: [ -> ]
(2015-01-04, 21:55)noap_ Wrote: [ -> ]After installing from "Get from ZIP file..." I'm being asked if I want to enable the new skin, which I confirm by Yes. After that I'm getting the error:
"unable to load skin: skin is missing some files"
I've tried versions 1.7.1, 1.7.3, 1.7.4, 2.0.0, and 2.0.1, always getting the same error. So it shouldn't be version related.
Running Kodi on Raspberry Pi.
Noone? :\
Having the same problem, I can see that the skin is being installed as skin.amber-master.
Hello.
Can you can send a copy from kodi.log file to Pastebin
and Post the link here ?
I've installed the master.zip file - how do I know if its really running the latest version? Can I see the version of the skin anywhere?
Under the add-ons menu, add-ons browser, go to the enabled add-on list, then select skins and Amber. That should give you the information screen, which includes the version number.
Best skin available, I too was getting this error too
This was due to updating from gotham to kodi and the old amber files still being installed, you need to manually remove the skin amber from /storage/.kodi/addons
restart just to be safe, then reinstall the new version
Have a Fire TV running Kodi 14.0 Does Amber work with it? I tried installing but I get a dependencies error.
Looks great man, love the picture for the live TV background.
(2015-01-06, 12:53)swehawk Wrote: [ -> ]Hmmm.... Could be that I deinstalled Amber after the first failed install. Maybe......
Gonna try it on my Pi also, but first have to sort out a more urgent problem with raspbmc Helix freezing up Sad
(2015-01-06, 22:48)cathaldub Wrote: [ -> ]Best skin available, I too was getting this error too
I tried after removing old installation but same message...
(2015-01-06, 20:07)Sam Lowry Wrote: [ -> ]For those who were getting the "structure is incorrect" problem on FireTV. You need to rename both the file AND the main folder within.
(2015-01-06, 20:55)SuperBilleN Wrote: [ -> ]Hi all with install problems.
please try it
worked for me
Also try this but same message. But when i replace "-" by "." i'm able to see Amber in the list of skin...
Even the 2.0.3 doesn't work for me... Sad
(2015-01-06, 23:47)kenz Wrote: [ -> ]Have a Fire TV running Kodi 14.0 Does Amber work with it? I tried installing but I get a dependencies error.
please try it
worked for me
Ok, i don't know why but it works !!!!
I guess it was old installation of amber...
Thanks to all !
