Full Version: Amber now updated to support Kodi 14.0\Helix
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
(2015-05-22, 00:52)boredazfcuk Wrote: [ -> ]I've noticed recently that if my screensaver is activated for a long time, it won't un-dim and I have to restart Kodi... This happens on both my RPi2 (Latest Openelec) and my Lubuntu VM (Helix 14.2) which does nothing but host the SQL DB and scrape data.
It is has only started happening recently so presuming it's a skin thing?
Thanks Smile
Can you recreate that with a debug log running ?
(2015-05-22, 15:52)Jester Wrote: [ -> ]Can you recreate that with a debug log running ?
It's only happened about two or three times in the past 6 weeks and all my devices are on 24x7. I'm not sure what's triggering it so I can't really reproduce it. I just flick over to the RPis or connect to the VM and when I start using it, it stays dimmed... I've set the trace running on my server though and will do the RPis when I get back from work.
I'm not sure if it's a coincidence (or whether I'm remembering it correctly) but I think the skin had been updated after the forced reboot. I'll make sure to check after the next skin update goes live. Could it be that if the skin update is performed while the screen is dimmed, it wipes out a dimmed=true flag or something? When I then start using it again, it checks the flag, new skin's default is dimmed=false and it doesn't send the signal to un-dim the screen? I dunno, I'm just brainstorming here lol
Something I just noticed is that the favorites icons aren't the right aspect ratio. They're way too square.
(2015-05-22, 17:20)boredazfcuk Wrote: [ -> ]It's only happened about two or three times in the past 6 weeks and all my devices are on 24x7. I'm not sure what's triggering it so I can't really reproduce it. I just flick over to the RPis or connect to the VM and when I start using it, it stays dimmed... I've set the trace running on my server though and will do the RPis when I get back from work.
I have experienced the same problem. The way I am dealing with it is that I do the skin reload.
After that everything works fine.
To me, it happens few times per day. I can provide logs if it can help, just tell me what to provide.
Thanks for this great skin, it's my favorite skin so far.
Can't wait to see it updating to Isengard and support the labels for skip steps Smile
Not sure if this is a PleXBMC issue or an Amber skin issue but my attempts at troubleshooting have proven fruitless. I am running the latest stable version of Kodi (14.2), latest PleXBMC from Hippojay's github, and the latest update from the repo for Amber (17).
When I try to open up Kodi, the screen flickers but my libraries do not appear and I get a Script Failed error for Plexbmc. I still have access to my Plex libraries because if I go into the add on through the add ons menu I can see the sections on my server, I am just not seeing them on the main screen. The following is the kodi log I took :
01:17:42 T:1783596656 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:17:42 T:1783596656 NOTICE: -----------------------------------------------------------------------
01:17:42 T:1783596656 NOTICE: Starting Kodi (14.2 Git:2015-03-26-7cc53a9-dirty). Platform: Android ARM 32-bit
01:17:42 T:1783596656 NOTICE: Using Release Kodi x32 build
01:17:42 T:1783596656 NOTICE: Kodi compiled Mar 26 2015 by GCC 4.8.0 for Android ARM 32-bit API level 14 (API level 14)
01:17:42 T:1783596656 NOTICE: Running on Matricom G-Box Q with Android 4.4.2 API level 19, kernel: Linux ARM 32-bit version 3.10.33
01:17:42 T:1783596656 NOTICE: FFmpeg version: 14.2rc1-Helix-5-g7cc53a9-xbmc-2.4.6-Helix
01:17:42 T:1783596656 NOTICE: Host CPU: ARMv7 Processor rev 1 (v7l), 2 cores available
01:17:42 T:1783596656 NOTICE: Product: matricom_k200, Device: k200, Board: k200 - Manufacturer: Matricom, Brand: G-Box, Model: G-Box Q, Hardware: amlogic
01:17:42 T:1783596656 NOTICE: ARM Features: Neon enabled
01:17:42 T:1783596656 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
01:17:42 T:1783596656 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
01:17:42 T:1783596656 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
01:17:42 T:1783596656 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
01:17:42 T:1783596656 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
01:17:42 T:1783596656 NOTICE: The executable running is:
01:17:42 T:1783596656 NOTICE: Local hostname: localhost
01:17:42 T:1783596656 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
01:17:42 T:1783596656 NOTICE: load settings...
01:17:42 T:1783596656 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 19
01:17:42 T:1783596656 NOTICE: aml_present, rtn(0)
01:17:42 T:1783596656 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
01:17:42 T:1783596656 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
01:17:42 T:1783596656 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
01:17:42 T:1783596656 NOTICE: Found 1 Lists of Devices
01:17:42 T:1783596656 NOTICE: Enumerated AUDIOTRACK devices:
01:17:42 T:1783596656 NOTICE: Device 1
01:17:42 T:1783596656 NOTICE: m_deviceName : AudioTrack
01:17:42 T:1783596656 NOTICE: m_displayName : android
01:17:42 T:1783596656 NOTICE: m_displayNameExtra: audiotrack
01:17:42 T:1783596656 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
01:17:42 T:1783596656 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
01:17:42 T:1783596656 NOTICE: m_sampleRates : 48000
01:17:42 T:1783596656 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
01:17:42 T:1783596656 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:17:42 T:1783596656 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
01:17:42 T:1783596656 NOTICE: Default DVD Player: dvdplayer
01:17:42 T:1783596656 NOTICE: Default Video Player: dvdplayer
01:17:42 T:1783596656 NOTICE: Default Audio Player: paplayer
01:17:42 T:1783596656 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:17:42 T:1783596656 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
01:17:42 T:1783596656 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
01:17:42 T:1783596656 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:17:42 T:1783596656 NOTICE: Loaded playercorefactory configuration
01:17:42 T:1783596656 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:17:42 T:1783596656 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:17:42 T:1802312632 NOTICE: Thread ActiveAE start, auto delete: false
01:17:42 T:1802390096 NOTICE: Thread AESink start, auto delete: false
01:17:42 T:1783596656 NOTICE: Running database version Addons16
01:17:42 T:1783596656 NOTICE: ADDONS: Using repository repository.xbmc.org
01:17:42 T:1783596656 ERROR: Unable to load libcec.so, reason: (null)
01:17:42 T:1783596656 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
01:17:42 T:1802300440 NOTICE: Thread PeripBusUSB start, auto delete: false
01:17:42 T:1783596656 WARNING: aml_permissions: missing su, playback might fail
01:17:42 T:1783596656 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
01:17:42 T:1783596656 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
01:17:42 T:1783596656 NOTICE: Previous line repeats 1 times.
01:17:42 T:1783596656 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
01:17:42 T:1783596656 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
01:17:42 T:1783596656 NOTICE: Checking resolution 16
01:17:42 T:1783596656 NOTICE: GL_VENDOR = ARM
01:17:42 T:1783596656 NOTICE: GL_RENDERER = Mali-450 MP
01:17:42 T:1783596656 NOTICE: GL_VERSION = OpenGL ES 2.0
01:17:42 T:1783596656 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
01:17:42 T:1783596656 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
01:17:42 T:1783596656 NOTICE: No Joystick name specified, loading default map
01:17:42 T:1783596656 NOTICE: Previous line repeats 36 times.
01:17:42 T:1783596656 NOTICE: Running database version ViewModes6
01:17:42 T:1783596656 NOTICE: Running database version Textures13
01:17:42 T:1783596656 NOTICE: Running database version MyMusic48
01:17:43 T:1783596656 NOTICE: Running database version MyVideos90
01:17:43 T:1783596656 NOTICE: Running database version TV26
01:17:43 T:1783596656 NOTICE: Running database version Epg8
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
01:17:43 T:1783596656 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
01:17:43 T:1844686400 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:43 T:1783596656 NOTICE: Previous line repeats 2 times.
01:17:43 T:1783596656 NOTICE: initialize done
01:17:43 T:1783596656 NOTICE: Running the application...
01:17:43 T:1783596656 NOTICE: starting zeroconf publishing
01:17:43 T:1783596656 NOTICE: starting upnp renderer
01:17:43 T:1848178632 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:43 T:1849449440 NOTICE: Thread JobWorker start, auto delete: true
01:17:43 T:1849243360 NOTICE: Thread ZerocconfEmbedded start, auto delete: false
01:17:43 T:1783596656 NOTICE: ES: Starting event server
01:17:43 T:1854962672 NOTICE: Thread TCPServer start, auto delete: false
01:17:43 T:1854959208 NOTICE: Thread EventServer start, auto delete: false
01:17:43 T:1854959208 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
01:17:43 T:1854959208 NOTICE: UDP: Listening on port 9777
01:17:43 T:1783596656 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
01:17:43 T:1783596656 NOTICE: GL_VENDOR = ARM
01:17:43 T:1783596656 NOTICE: GL_RENDERER = Mali-450 MP
01:17:43 T:1783596656 NOTICE: GL_VERSION = OpenGL ES 2.0
01:17:43 T:1783596656 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
01:17:43 T:1783596656 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug
01:17:43 T:1815986920 NOTICE: Thread AirPlayServer start, auto delete: false
01:17:43 T:1849399448 NOTICE: Thread JobWorker start, auto delete: true
01:17:43 T:1844687328 NOTICE: -->Python Interpreter Initialized<--
01:17:44 T:1870235864 NOTICE: Previous line repeats 3 times.
01:17:44 T:1870235864 NOTICE: Thread JobWorker start, auto delete: true
01:17:44 T:1891965584 NOTICE: Thread LanguageInvoker start, auto delete: false
01:17:44 T:1892547944 NOTICE: Previous line repeats 2 times.
01:17:44 T:1892547944 NOTICE: Thread JobWorker start, auto delete: true
01:17:44 T:1891991136 NOTICE: Thread RSSReader start, auto delete: false
01:17:44 T:1892188640 NOTICE: -->Python Interpreter Initialized<--
01:17:45 T:1891965584 NOTICE: Previous line repeats 2 times.
01:17:45 T:1891965584 NOTICE: ===== PLEXBMC START [id: 1432617465.01] =====
01:17:45 T:1892188640 NOTICE: ===== PLEXBMC START [id: 1432617465.02] =====
01:17:45 T:1848178632 NOTICE: StorageServer Module loaded RUN
01:17:45 T:1848178632 NOTICE: StorageClient-2.5.4 Starting server
01:17:45 T:1891965584 NOTICE: PleXBMC -> Reading settings configuration
01:17:46 T:1891965584 NOTICE: Previous line repeats 1 times.
01:17:46 T:1891965584 NOTICE: PleXBMC.plexserver -> <module> : Using Requests version for HTTP: 2.6.0
01:17:46 T:1891965584 NOTICE: PleXBMC -> Running PleXBMC: 4.0.0~beta4
01:17:46 T:1891965584 NOTICE: PleXBMC -> Script argument is ['default.py', 'amberskin', 'nocat']
01:17:46 T:1891965584 NOTICE: PleXBMC -> Running Python: (2, 6, 5, 'final', 0)
01:17:46 T:1891965584 NOTICE: PleXBMC -> CWD is set to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix
01:17:46 T:1891965584 NOTICE: PleXBMC -> Platform: Linux/RPi
01:17:46 T:1891965584 NOTICE: PleXBMC -> Setting debug: debug+
01:17:46 T:1891965584 NOTICE: PleXBMC -> FullRes Thumbs are set to: True
01:17:46 T:1891965584 NOTICE: PleXBMC -> Settings streaming: 0
01:17:46 T:1891965584 NOTICE: PleXBMC -> Setting filter menus: True
01:17:46 T:1891965584 NOTICE: PleXBMC -> Flatten is: 0
01:17:46 T:1891965584 NOTICE: PleXBMC -> Setting stream Control to : PLEX CONTROL
01:17:46 T:1891965584 NOTICE: PleXBMC -> Force DVD playback: False
01:17:46 T:1891965584 NOTICE: PleXBMC -> SMB IP Override: False
01:17:46 T:1891965584 NOTICE: setting: nasoverrideip is :
01:17:46 T:1891965584 NOTICE: PleXBMC -> NAS IP:
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> __init__ : Running with cache location: special://profile/addon_data/plugin.video.plexbmc/cache/servers/
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: attempting to read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: data: [(dp1
S'plexhome_user_cache'
p2
S''
sS'plexhome_user_avatar'
p3
S'http://www.gravatar.com/avatar/20d9e16860fd37079aae941b76258534?d=https%3A%2F%2Fplex.tv%2Favatars%2F7EB0D5%2F52%2F1'
p4
sS'plexhome_enabled'
p5
I00
sS'myplex_signedin'
p6
I01
sS'myplex_user_cache'
p7
S'<omitted>'
p8
s.]
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> load_tokencache : plexhome_cache data loaded successfully
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : Myplex is logged in
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : No user set. Will default to admin user
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> writeCache : CACHE [plexhome_user.pcache]: Writing file
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : myplex userid: <omitted>
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> setup_user_token : effective userid: <omitted>
01:17:46 T:1891965584 NOTICE: PleXBMC -> get_params : == ENTER ==
01:17:46 T:1891965584 NOTICE: PleXBMC -> get_params : Parameter string: nocat
01:17:46 T:1891965584 NOTICE: PleXBMC -> Detected parameters: {}
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> load : Loading cached server list
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: exists
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: mod[1432617067] now[1432617467] diff[400]
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: current
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: attempting to read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: read
01:17:46 T:1891965584 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: data: [(dp1
S'02b2d81bac6fb5e9f92b26386e96a54ff760f785'
p2
(iplexserver
PlexMediaServer
p3
(dp4
S'protocol'
p5
S'http'
p6
sS'plex_home_enabled'
p7
I00
sS'owned'
p8
I1
sS'discovered'
p9
I00
sS'plex_identification_string'
p10
S'X-Plex-Platform=KODI&X-Plex-Client-Platform=KODI&X-Plex-User=<omitted>&X-Plex-Device-Name=Livingroom&X-Plex-Provides=player&X-Plex-Token=UeRSfDzEqKohiYdrg3wM&X-Plex-Model=unknown&X-Plex-Platform-Version=Linux/RPi&X-Plex-Client-Identifier=4b6fb3d6-5f26-45ee-86df-804b1ee6a742&X-Plex-Device=PleXBMC&X-Plex-Product=PleXBMC&X-Plex-Language=en&X-Plex-Version=4.0.0%7Ebeta4'
p11
sS'external_port'
p12
S'13020'
p13
sS'plex_identification_header'
p14
(dp15
S'X-Plex-Platform'
p16
S'KODI'
p17
sS'X-Plex-Client-Platform'
p18
g17
sS'X-Plex-User'
p19
S'<omitted>'
p20
sS'X-Plex-Device-Name'
p21
S'Livingroom'
p22
sS'X-Plex-Provides'
p23
S'player'
p24
sS'X-Plex-Token'
p25
S'UeRSfDzEqKohiYdrg3wM'
p26
sS'X-Plex-Model'
p27
S'unknown'
p28
sS'X-Plex-Platform-Version'
p29
S'Linux/RPi'
p30
sS'X-Plex-Client-Identifier'
p31
S'4b6fb3d6-5f26-45ee-86df-804b1ee6a742'
p32
sS'X-Plex-Device'
p33
S'PleXBMC'
p34
sS'X-Plex-Product'
p35
g34
sS'X-Plex-Language'
p36
S'en'
p37
sS'X-Plex-Version'
p38
S'4.0.0~beta4'
p39
ssS'uuid'
p40
g2
sS'server_name'
p41
S'CarusoNAS01'
p42
sS'local_port'
p43
NsS'access_port'
p44
g13
sS'master'
p45
I1
sS'local_address'
p46
(lp47
S'192.168.1.130'
p48
asS'offline'
p49
I00
sS'_PlexMediaServer__revision'
p50
S'1.0.7'
p51
sS'discovery'
p52
S'myplex'
p53
sS'class_type'
p54
S'primary'
p55
sS'section_list'
p56
(lp57
sS'user'
p58
g20
sS'client_id'
p59
g32
sS'external_address'
p60
S'<ommitted>'
p61
sS'best_address'
p62
S'address'
p63
sS'device_name'
p64
g22
sS'token'
p65
g26
sS'access_address'
p66
g61
sbs.]
01:17:46 T:1891965584 NOTICE: PleXBMC.plex -> load : Server list is now: {'02b2d81bac6fb5e9f92b26386e96a54ff760f785': <plexserver.PlexMediaServer instance at 0x71c74c70>}
01:17:46 T:1891965584 NOTICE: PleXBMC -> amberskin : == ENTER ==
01:17:46 T:1891965584 NOTICE: PleXBMC -> amberskin : Using list of 1 servers: [<plexserver.PlexMediaServer instance at 0x71c74c70>]
01:17:46 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : URL is: /library/sections
01:17:47 T:1892188640 NOTICE: PleXBMC.plexserver -> <module> : Using Requests version for HTTP: 2.6.0
01:17:47 T:1892188640 NOTICE: PleXBMC -> Running PleXBMC: 4.0.0~beta4
01:17:47 T:1892188640 NOTICE: PleXBMC -> Script argument is ['default.py', 'channelShelf']
01:17:47 T:1892188640 NOTICE: PleXBMC -> Running Python: (2, 6, 5, 'final', 0)
01:17:47 T:1892188640 NOTICE: PleXBMC -> CWD is set to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix
01:17:47 T:1892188640 NOTICE: PleXBMC -> Platform: Linux/RPi
01:17:47 T:1892188640 NOTICE: PleXBMC -> Setting debug: debug+
01:17:47 T:1892188640 NOTICE: PleXBMC -> FullRes Thumbs are set to: True
01:17:47 T:1892188640 NOTICE: PleXBMC -> Settings streaming: 0
01:17:47 T:1892188640 NOTICE: PleXBMC -> Setting filter menus: True
01:17:47 T:1892188640 NOTICE: PleXBMC -> Flatten is: 0
01:17:47 T:1892188640 NOTICE: PleXBMC -> Setting stream Control to : PLEX CONTROL
01:17:47 T:1892188640 NOTICE: PleXBMC -> Force DVD playback: False
01:17:47 T:1892188640 NOTICE: PleXBMC -> SMB IP Override: False
01:17:47 T:1892188640 NOTICE: setting: nasoverrideip is :
01:17:47 T:1892188640 NOTICE: PleXBMC -> NAS IP:
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> __init__ : Running with cache location: special://profile/addon_data/plugin.video.plexbmc/cache/servers/
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: attempting to read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [plexhome_user.pcache]: data: [(dp1
p2
S''
p3
I00
p4
p5
sS'myplex_signedin'
p6
I01
p7
S'<omitted>'
p8
s.]
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> load_tokencache : plexhome_cache data loaded successfully
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : Myplex is logged in
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : No user set. Will default to admin user
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> writeCache : CACHE [plexhome_user.pcache]: Writing file
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : myplex userid: <omitted>
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> setup_user_token : effective userid: <omitted>
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> load : Loading cached server list
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: exists
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: mod[1432617067] now[1432617467] diff[400]
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> checkCache : CACHE [discovered_plex_servers.cache]: current
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: attempting to read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: read
01:17:47 T:1892188640 NOTICE: PleXBMC.cachecontrol -> readCache : CACHE [discovered_plex_servers.cache]: data: [(dp1
p2
(iplexserver
PlexMediaServer
p3
(dp4
S'protocol'
p5
S'http'
p6
p7
I00
sS'owned'
p8
I1
sS'discovered'
p9
I00
p10
p11
sS'external_port'
p12
S'13020'
p13
p14
(dp15
S'X-Plex-Platform'
p16
S'KODI'
p17
p18
g17
sS'X-Plex-User'
p19
S'<omitted>'
p20
p21
S'Livingroom'
p22
sS'X-Plex-Provides'
p23
S'player'
p24
sS'X-Plex-Token'
p25
p26
sS'X-Plex-Model'
p27
S'unknown'
p28
p29
S'Linux/RPi'
p30
p31
p32
sS'X-Plex-Device'
p33
S'PleXBMC'
p34
sS'X-Plex-Product'
p35
g34
sS'X-Plex-Language'
p36
S'en'
p37
sS'X-Plex-Version'
p38
S'4.0.0~beta4'
p39
ssS'uuid'
p40
g2
sS'server_name'
p41
S'CarusoNAS01'
p42
sS'local_port'
p43
NsS'access_port'
p44
g13
sS'master'
p45
I1
sS'local_address'
p46
(lp47
S'192.168.1.130'
p48
asS'offline'
p49
I00
p50
S'1.0.7'
p51
sS'discovery'
p52
S'myplex'
p53
sS'class_type'
p54
S'primary'
p55
sS'section_list'
p56
(lp57
sS'user'
p58
g20
sS'client_id'
p59
g32
p60
S'<omitted>'
p61
sS'best_address'
p62
S'address'
p63
sS'device_name'
p64
g22
sS'token'
p65
g26
sS'access_address'
p66
g61
sbs.]
01:17:47 T:1892188640 NOTICE: PleXBMC.plex -> load : Server list is now: {'02b2d81bac6fb5e9f92b26386e96a54ff760f785': <plexserver.PlexMediaServer instance at 0x72b37ee8>}
01:17:47 T:1892188640 NOTICE: PleXBMC -> shelfChannel : == ENTER ==
01:17:47 T:1892188640 NOTICE: PleXBMC -> shelfChannel : Disabling channel shelf
01:17:47 T:1892188640 NOTICE: PleXBMC -> clearChannelShelf : Done clearing channels
01:17:47 T:1892188640 NOTICE: ===== PLEXBMC STOP [id: 1432617465.02]: 2.43537402153 seconds =====
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : URL was: http://<omitted>/library/sections?X-Plex-Platform=KODI&X-Plex-Token=UeRSfDzEqKohiYdrg3wM&X-Plex-Platform-Version=Linux%2FRPi&X-Plex-Client-Platform=KODI&X-Plex-User=<omitted>&X-Plex-Client-Identifier=4b6fb3d6-5f26-45ee-86df-804b1ee6a742&X-Plex-Device=PleXBMC&X-Plex-Product=PleXBMC&X-Plex-Language=en&X-Plex-Model=unknown&X-Plex-Device-Name=Livingroom&X-Plex-Provides=player&X-Plex-Version=4.0.0~beta4
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : Response: 200 OK - Encoding: utf-8
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : ===XML===
<?xml version="1.0" encoding="UTF-8"?>
<MediaContainer size="13" allowSync="0" identifier="com.plexapp.plugins.library" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1431042673" title1="Plex Library">
<Directory allowSync="1" art="/:/resources/photo-fanart.jpg" composite="/library/sections/20/composite/1432567236" filters="1" refreshing="0" thumb="/:/resources/photo.png" key="20" type="photo" title="ChrisPhonePics" agent="com.plexapp.agents.none" scanner="Plex Photo Scanner" language="xn" uuid="0b53cac8-3507-47fa-8a28-1a7f84af5712" updatedAt="1432567236" createdAt="1432318793">
<Location id="25" path="/apps/plexmediaserver/MediaLibrary/Plex Media Server/Media Upload/ChrisPhonePics" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/21/composite/1432569036" filters="1" refreshing="0" thumb="/:/resources/video.png" key="21" type="movie" title="Home Videos" agent="com.plexapp.agents.none" scanner="Plex Video Files Scanner" language="xn" uuid="84ad603c-ba62-404c-bff7-df10706e60f9" updatedAt="1432569036" createdAt="1432386250">
<Location id="26" path="/CarusoVol01/media/Family Videos" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/1/composite/1432567237" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="1" type="movie" title="Kid Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="224ebb3f-a564-4e81-9291-da4e160ff798" updatedAt="1432567237" createdAt="1424573600">
<Location id="1" path="/CarusoVol01/media/Kids/Movies" />
</Directory>
<Directory allowSync="1" art="/:/resources/show-fanart.jpg" composite="/library/sections/3/composite/1432567239" filters="1" refreshing="0" thumb="/:/resources/show.png" key="3" type="show" title="Kid Shows" agent="com.plexapp.agents.thetvdb" scanner="Plex Series Scanner" language="en" uuid="b9417575-575c-4a82-808b-9b2a6224e1b0" updatedAt="1432567239" createdAt="1424580761">
<Location id="3" path="/CarusoVol01/media/Kids/Shows" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/22/composite/1432569038" filters="1" refreshing="0" thumb="/:/resources/video.png" key="22" type="movie" title="Mobile Home Videos" agent="com.plexapp.agents.none" scanner="Plex Video Files Scanner" language="xn" uuid="61a82f85-205c-44c2-8905-7fe180192bab" updatedAt="1432569038" createdAt="1432466215">
<Location id="27" path="/CarusoVol01/Mobile/Family Videos" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/11/composite/1432567240" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="11" type="movie" title="Mobile Kids Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="c9dc5030-7d61-4c0b-ab1d-b4b39c919862" updatedAt="1432567240" createdAt="1426941097">
<Location id="13" path="/CarusoVol01/Mobile/Kids/Movies" />
</Directory>
<Directory allowSync="1" art="/:/resources/show-fanart.jpg" composite="/library/sections/12/composite/1432567242" filters="1" refreshing="0" thumb="/:/resources/show.png" key="12" type="show" title="Mobile Kids Shows" agent="com.plexapp.agents.thetvdb" scanner="Plex Series Scanner" language="en" uuid="5c0918a9-e661-4bd6-bcae-59c5343a9858" updatedAt="1432567242" createdAt="1427131136">
<Location id="14" path="/CarusoVol01/Mobile/Kids/Shows" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/7/composite/1432567291" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="7" type="movie" title="Mobile Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="ceb0c7ac-44bb-4c1d-9100-e3a81b7deb31" updatedAt="1432567291" createdAt="1424636462">
<Location id="8" path="/CarusoVol01/Mobile/Theatrical Releases" />
</Directory>
<Directory allowSync="1" art="/:/resources/photo-fanart.jpg" composite="/library/sections/23/composite/1432569039" filters="1" refreshing="0" thumb="/:/resources/photo.png" key="23" type="photo" title="Mobile Photos" agent="com.plexapp.agents.none" scanner="Plex Photo Scanner" language="xn" uuid="4ba67226-7890-42b0-a869-2bfff6179c3e" updatedAt="1432569039" createdAt="1432558697">
<Location id="28" path="/apps/plexmediaserver/MediaLibrary/Plex Media Server/Media Upload/Mobile Photos" />
</Directory>
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/4/composite/1432567301" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="4" type="movie" title="Movies" agent="com.plexapp.agents.imdb" scanner="Plex Movie Scanner" language="en" uuid="dd5eabb6-8104-4d42-9a45-dbbf46856fc7" updatedAt="1432567301" createdAt="1424584228">
<Location id="4" path="/CarusoVol01/media/Theatrical Releases" />
</Directory>
<Directory allowSync="1" art="/:/resources/artist-fanart.jpg" composite="/library/sections/18/composite/1432567302" filters="1" refreshing="0" thumb="/:/resources/artist.png" key="18" type="artist" title="Music" agent="com.plexapp.agents.plexmusic" scanner="Plex Premium Music Scanner" language="en" uuid="a0cf4eab-390e-42fb-94a3-368af7785b67" updatedAt="1432567302" createdAt="1430851809">
<Location id="23" path="/CarusoVol01/media/Music/Chris" />
</Directory>
<Directory allowSync="1" art="/:/resources/photo-fanart.jpg" composite="/library/sections/9/composite/1432567310" filters="1" refreshing="0" thumb="/:/resources/photo.png" key="9" type="photo" title="Photos" agent="com.plexapp.agents.none" scanner="Plex Photo Scanner" language="xn" uuid="d217628e-35ef-4c88-a853-e91c46e63eb2" updatedAt="1432567310" createdAt="1425433753">
<Location id="10" path="/apps/plexmediaserver/MediaLibrary/Plex Media Server/Media Upload/Photos" />
<Location id="11" path="/CarusoVol01/media/Pictures/Pictures" />
</Directory>
<Directory allowSync="1" art="/:/resources/show-fanart.jpg" composite="/library/sections/5/composite/1432567322" filters="1" refreshing="0" thumb="/:/resources/show.png" key="5" type="show" title="TV Shows" agent="com.plexapp.agents.thetvdb" scanner="Plex Series Scanner" language="en" uuid="aa789d4b-c4c4-42ed-a106-f8e3ffb0e83e" updatedAt="1432567322" createdAt="1424633102">
<Location id="5" path="/CarusoVol01/media/TV Shows" />
</Directory>
</MediaContainer>
===XML===
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> talk : DOWNLOAD: It took 0.89 seconds to retrieve data from <omitted>
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> processed_xml : PARSE: it took 0.02 seconds to parse data from <omitted>
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> get_sections : Returning sections: [<plexserver.plex_section instance at 0x7296e8d8>, <plexserver.plex_section instance at 0x71d40a10>, <plexserver.plex_section instance at 0x71d21888>, <plexserver.plex_section instance at 0x7270cb10>, <plexserver.plex_section instance at 0x72b25050>, <plexserver.plex_section instance at 0x7271b700>, <plexserver.plex_section instance at 0x727bb4b0>, <plexserver.plex_section instance at 0x7276cae0>, <plexserver.plex_section instance at 0x726d4e28>, <plexserver.plex_section instance at 0x72771d80>, <plexserver.plex_section instance at 0x726d4e70>, <plexserver.plex_section instance at 0x726d6cf0>, <plexserver.plex_section instance at 0x72ab9fa0>]
01:17:47 T:1891965584 NOTICE: PleXBMC -> amberskin : =Enter amberskin section=
01:17:47 T:1891965584 NOTICE: PleXBMC -> amberskin : {'art': '/:/resources/photo-fanart.jpg', 'title': 'ChrisPhonePics', 'sectionuuid': '0b53cac8-3507-47fa-8a28-1a7f84af5712', 'location': 'local', 'key': '20', 'path': '/library/sections/20', 'type': 'photo'}
01:17:47 T:1891965584 NOTICE: PleXBMC -> amberskin : =/section=
01:17:47 T:1891965584 NOTICE: PleXBMC.plexserver -> get_fanart : Getting fanart for ChrisPhonePics
01:17:47 T:1891965584 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnboundLocalError'>
Error Contents: local variable 'mode' referenced before assignment
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix/default.py", line 13, in <module>
plexbmc.start_plexbmc()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix/resources/lib/plexbmc.py", line 4120, in start_plexbmc
amberskin()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.plexbmc-helix/resources/lib/plexbmc.py", line 2819, in amberskin
WINDOW.setProperty("plexbmc.%d.year" % (sectionCount) , "ActivateWindow(%s,%s%s%s&mode=%s,return)" % (window, base_url, path, "/year", mode) )
UnboundLocalError: local variable 'mode' referenced before assignment
01:17:51 T:1783596656 NOTICE: Storing total System Uptime
01:17:51 T:1783596656 NOTICE: Saving settings
01:17:51 T:1783596656 NOTICE: stop all
01:17:51 T:1783596656 NOTICE: stop player
01:17:51 T:1783596656 NOTICE: ES: Stopping event server
01:17:52 T:1854959208 NOTICE: ES: UDP Event server stopped
01:17:52 T:1783596656 NOTICE: stopping upnp
01:17:52 T:1783596656 NOTICE: stopping zeroconf publishing
01:17:52 T:1783596656 NOTICE: stop sap announcement listener
01:17:52 T:1783596656 NOTICE: clean cached files!
01:17:52 T:1783596656 NOTICE: unload skin
01:17:53 T:1848178632 NOTICE: StorageServer-2.5.4 Closed down
01:17:53 T:1844686400 WARNING: CPythonInvoker(1, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.skin.widgets/default.py): the python script "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.skin.widgets/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE
01:17:53 T:1783596656 NOTICE: stopped
01:17:53 T:1783596656 NOTICE: destroy
01:17:53 T:1783596656 NOTICE: unload sections
01:17:53 T:1783596656 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:17:53 T:1783596656 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
01:17:53 T:1783596656 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
01:17:53 T:1783596656 NOTICE: application stopped...
(2015-05-26, 16:56)rockcjc Wrote: [ -> ]When I try to open up Kodi, the screen flickers but my libraries do not appear and I get a Script Failed error for Plexbmc. I still have access to my Plex libraries because if I go into the add on through the add ons menu I can see the sections on my server, I am just not seeing them on the main screen.
Looks like a bug in a plexbmc related to a code that is used with Amber skin integration (Different code is used when plexbmc is run via add-ons). You should post this debug log plexbmc thread so that hippojay can fix it.
I am looking into extending “custom items”, so they can link to (fx. Video) nodes. I have looked at the code, and added support for “script.skinshortcuts”. It has a management part, what can add actions to nodes, favourites (shortcuts wiki says “Create shortcuts to almost anything - library, add-ons, favourites, sources, UPnP and more “), much like script.favourites. (wiki: http://kodi.wiki/view/Add-on:%20Skin%20Shortcuts)
Right now I have only changed things in settings.xml - and extended the functionality so if “script.skinshortcuts” is installed it is used instead of script.favourites. (it does not look like any other files need changes).
So is this a feature you (@Jester ?) are interested in and want to add to the repository? Maybe script.favourites should be replaced by script.skinshortcuts – I can make changes for that, if you can that instead.
I am new to all of this, skins, scripts, git etc., but after an hour of looking a the Nox and the Amber code base, it looks simple enough and had a working copy.
My interest in making these changes is that I want to use the more powerful features, then just using farvorites. When adding support for nodes, people have a powerful way of customize the kodi/amber experience. Eg. A kid and a parent node, whre the kid/parent note displays only the kids/parent content.
(2015-05-26, 19:09)pecinko Wrote: [ -> ]
I appreciate your quick response. Unfortunately, I think Hippojay is on vacation through the end of May. Whats odd is that everything was working just fine and then all of a sudden it wasn't. I hadn't made any updates, although it appears that Amber now updates from the repo so I no longer need to do any manual updates using the zip from Github.
Was something changed on the Amber side that Plexbmc is not set up to handle appropriately? Also seems odd that I would be the only one reporting this issue which leaves me to believe it is something on my end, but again, I couldn't see anything in the log to troubleshoot.
(2015-05-27, 20:17)rockcjc Wrote: [ -> ]this issue which leaves me to believe it is something on my end, but again, I couldn't see anything in the log to troubleshoot.
PHP Code:
21:27:19 T:4607021056   ERROREXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
NOTEIGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Contentslocal variable 'mode' referenced before assignment
                                            Traceback
File "/Users/peca/Library/Application Support/Kodi/addons/plugin.video.plexbmc/default.py"line 13in <module>
File "/Users/peca/Library/Application Support/Kodi/addons/plugin.video.plexbmc/resources/lib/plexbmc.py"line 4120in start_plexbmc
                                                amberskin
File "/Users/peca/Library/Application Support/Kodi/addons/plugin.video.plexbmc/resources/lib/plexbmc.py"line 2819in amberskin
                                                WINDOW
.setProperty("plexbmc.%d.year" % (sectionCount) , "ActivateWindow(%s,%s%s%s&mode=%s,return)" % (windowbase_urlpath"/year"mode) )
UnboundLocalErrorlocal variable 'mode' referenced before assignment
21:27:19 T:4613214208  NOTICE: ===== PLEXBMC STOP [id1432754838.61]: 0.774287939072 seconds =====
(2015-05-27, 21:50)pecinko Wrote: [ -> ]
PHP Code:
                                            Traceback
                                                amberskin
                                                WINDOW
Let me rephrase, I couldn't find anything in the log that my puny non-developer brain could use to troubleshoot :-). I did see these error lines and ran some google searches as well as tried a few things on my end that I thought might be associated, but all ended up fruitless.
It has been mentioned in the plex forums that perhaps I should be using the repo version instead of the version from github. I was previously on the version just prior to the most recent that is out on Github and Kodi automatically updated the version with the one that is on the repo. This is another reason I thought perhaps it was an update to the skin that caused the issue.
Is there any difference between what is in the repo and what is on Github? Should I uninstall the Amber skin and then reinstall it from the repo (or am I just spinning wheels with false hopes).
Nothing to do with skin, plexbmc issue.
Hi All
Hoping someone can help?
I am running Kodi 14 Helix on my windows machine with Amber but cannot find the TV Shows on the main screen am I being dumb? do I need to enable it?
Mark
(2015-05-23, 19:32)Smultie Wrote: [ -> ]Something I just noticed is that the favorites icons aren't the right aspect ratio. They're way too square.
Anyone with the same issue, or is this somehow just me?
I do not if you have seen this issue before or it has been fixed in a newer version but here it is:
I disabled the Live TV option from the Home Shelf and when I want to re-enable it again I get only prompted to add Favorites. The TV and PVRs have been enabled. Let me know if you need more info but it can easily be re-created. I could probably fix it through the guisettings.xml. Let me know if you know the section that needs to be edited
Love the skin, I'm using Helix 14.2 on A RPI2 and Openelec 5.08
Thanks,
Jack P
