Full Version: Amber Skin: Where Should Custom Icon Image Files Go?
I have designed my own addon which utilities its own images for icons.
These worked fine in other skins, by copying the images to the /home/pi/.xbmc/addons/[skinname]/media
However for some reason this doesn't seem to work for the amber skin for Gotham? I noticed the folder above is actually empty too prior to me copying the files
Can anyone tell me where the default media directory is for amber?
as a follow up I was unable to fix this however pointing the thumbnails to the same files seems to work as a a workaround
Are you sure it was empty? It will either contain loads of images or a single texture.xbt file.
