Full Version: Version 2.6
After a few months of heavy code cleanups, implementing new features and an UI rework (approx. 180 commits) we are proud to announce
tinyMediaManager version 2.6
The biggest change in version 2.6 is the donator version. Registering as a donator will unlock some really nice features. Read more about it in http://www.tinymediamanager.org/index.ph...r-version/.
Full changelog:
06. Sept. 2014 - Version 2.6
DONATOR VERSION
Our donators are now able to register their tinyMediaManager copies to unlock special features as a “Thank you” for their support. http://goo.gl/L8G5BB
! trailer downloading (donator feature) (http://goo.gl/hozk18)
! Trakt.tv integration (donator feature) (http://goo.gl/WNEzsG)
! Movie renamer preview (donator feature) (http://goo.gl/PS50MF)
! automatically add existing movies to movie sets (donator feature)
+ bigger UI rework (http://goo.gl/3wy3gL)
+ configurable font and font size
+ preserve unsupported XML tags (from other tools) in NFO files
+ extra artwork (banner, CD art, clearart, ..) is now available for movies and movie sets
+ new threading model: you can now queue different tasks; display open tasks (http://goo.gl/yFGtPq)
+ preview of images in the image chooser (http://goo.gl/kIFaKJ)
+ smart scrape: if there is no result from automatic scrape a manual scrape will pop up
+ NFO enhancement: multiple IDs (from several meta data providers) will be stored
+ option to set the preferred media player
+ able to play trailers
+ trailer preferences (which one to automatic choose for NFO)
+ delete works now with deleting physical files (moving to backup folder)
+ ignore some Mac specific files on searching hdd/network shares
+ language updates
+ hotkeys for menu and other functions
+ improved season and episodes parser
+ several enhancements to the TV show renamer
+ show artwork from the media file panel in lightbox
+ export for TV shows basically done
+ more filter options for TV shows
+ media source management (http://goo.gl/cE62xb)
x fix occasional database inconsistencies
x fix TvShow rename in command line
x fix an occasional crash when choosing artwork
x empty url cache from broken/unreadable HTTP responses
x better integration of the year to the result score calculation
x filter duplicate results from ofdb
x prevent audio streams from being added multiple times
x detect stacking markers with leading zeros
x import of watched state from XBMC NFO
x thousands of various fixes and stabilization from past half year Smile
Is there a way to update the media source for existing movies without remaking the DB? I've tried "Update media information" however it did not work.
did you change the path to the data source of your movies? That is (at the moment) not possible - it would be kinda complex to relocate all paths in the DB (and that is not a common action too). So removing and readding the data source is the way to go..
Apologies for the dumb question, but where can I get the final version of 2.6? I went to the Downloads page off the tMM site and it only lists the 2.5.5 version.
Edit: Never mind, I reopened the application and it updated.
I did not have time to update the installers - but as you said: it is updating itself Smile
Does the new version now use the year to find the correct movie?
yes - if there is a year in the movie it will be used for a score calculation (which results in a better match for the "right" result)
Thank you, mlaggner,
That is very nice, the hit ratio before did not appear to be that good here, so I assume, almost the most of the movies will be hit correctly now.
Many thanks again.
