Full Version: compile bat?
hi, i was searching in the forum for any of the batch files,
that download + compiles in one click.
do anyone have somthing from a recently date?
is this one all uses?
are there other?
http://johnypcguru.home.mchsi.com/index.htm
thanks
edit
i'm testing the c+ version of the app now.
http://forums.xbox-scene.com/index.php?s...601&st=150
edit
it seems all compile in one click programs are all outdated on
what folders they copy. anyone has a batch program that is updated ?
(thor918 @ june 07 2006,15:53 Wrote:hi, i was searching in the forum for any of the batch files,
are there other?
thanks
edit
edit
i'm using this whitout any problems
i use xbmcdbr c# with some modifications.
i'm trying to get it released as an official version, and would like to help with further development.
trying to contact yuyu about this, but he's busy.
continued discussion on the x-s thread.
thor, that's the one i use to use and modified it slightly. if you would like it i could send it to you. the batch version not the c# version. the one i have does not ftp it though.
yepp, i got the batch version working,
but the finished packed file does not have all the correct folders copied. like "user data" ....
jgawera, i see...
how exactly did you get hold of the source?
didn't see it released anywhere.
hehe,
it wouldn't be any use for me anyway, since i'm working with lighter languages.
anyway would be interesting to test it when you get it released.
thanks
it's a sourceforge project.
http://sourceforge.net/projects/xbmctk
see here for a new build of xbmcdbr that should work correctly.
