Hey
I've got XBMC 13.1-RC1 installed on Ubuntu Gnome 14.10. I admit that this is not a recent installation however I finally have some free time to add a PVR and some IPTV channels. I've installed the backend and all however I came to installing the frontend when I hit a bump. My XBMC copy doesn't have the XBMC PVR repo installed. I want to know how I can add it.
(2014-09-08, 11:50)fritsch Wrote: [ -> ]Use Team xbmc ppa.
I'm assuming you're talking about the pvr ppa... Ok, so how do I add it. Yes I am a bit new to XBMC and repos. Haven't really experimented with them yet. What I do know is that 3rd party repos are added through a zip file. Is that the same with the Team XBMC ppa? If yes, where can I find it? If no, how then?
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xbmc-pvr-addons
(2014-09-08, 13:41)black_eagle Wrote: [ -> ]sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
Unfortunately, when I input
, the following appears:
W: Failed to fetch http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/dists/utopic/main/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/dists/utopic/main/binary-i386/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead
So I tried to install the pvr addons with
just in case an older repo is being used, however it wasn't located
No builds yet for 14.10 as its still in alpha. You can edit /etc/apt/sources.list.d/ for the ppa and change utopic to trusty. Then sudo apt-get update again.
