This is a great skin, just what I've been looking for, thanks!
I'm running the version from the media browser repo and have created some custom home menu items.
However, when using the reordering feature they cannot be moved from the bottom, any ideas on how this can be done?
You have to have a bit of patience with that reorder :-)
Just try it again for a coiple of times and you'll see that it will work.
There are invisible items (so positions) in the list that's why it won't always work at once.
Ah great, thanks. Will give it a go.
(2014-09-08, 07:13)tdw197 Wrote: [ -> ]Ah great, thanks. Will give it a go.
And did it work for you ? In the future I will make the re-ordering somewhat more robust. For now you just have to try a few times :-)
Hi - yes it did work, thanks very much. Sorry about not getting back, I've been on holiday.
I found I had to press up several times and pressing down several times on the item above to get them to move - but it did work in the end.
I fixed it in the latest version of the skin. It's now more user friendly...
