Full Version: Python serial script for TV control
I have a Samsung TV that I like to control by serial because I don't like the look of little IR transmitters.
Right now I have this:
import time, serial
ser = serial.Serial(port='/dev/ttyUSB0', baudrate=9600, timeout=1)
ser.write("\x08\x22\x00\x00\x00\x00\xd4")
ser.close()
And it works but often I have to run it 3 or 4 times before the TV responds.
I got this started:
import time, serial
while True:
    data = ser.read(3)
    if len(data) > 0:
        print 'sucess'
    sleep(0.5)
    print 'Retrying'
ser.close()
The problem is this will just keep going over and over even if it does read some data. The TV responds with 3 bytes when theres a successful command. Ideally I would like this to keep trying until it gets those three bytes. (03 0c f1) can someone help me make this work the way I want?
Thanks!!!
never used serial, but did you try the obvious:
while (data != "03 0c f1"):
  data = ser.read(3)
  sleep(0.5)
ser.close()
you'll have to check what "data" holds on a successful event and use that in the while clause.
When I print the data variable I just get my whole terminal cleared and a odd little single character sized box in the top left corner. How can I get it to print the hex value?
I found the solution to everything by accident. The reason I needed this to loop is the tv was not reliably responding to my command. I tried sending a command I thought would make the tv respond with its power status. However it actually more reliably turns the tv on and off.
For anyone looking for this solution I have used this simple code.
import time, serial
ser.write("\x08\x22\x00\x00\x00\x00\xd6")
ser.close()
