Full Version: Kodi crashing when going into list of videos
Hi everyone,
I'm using the latest nightly and for the last few days whenever i go into the list of tv shows, movies or videos, kodi crashes and is sent back to the home screen after restarting.
I have removed nightly and tried stable and unstable releases but they still have remote issues for which why i was using nightlies in the first place.
Is it just a big with the nightly or is there something wrong?
Uninstall tvtunes.
(2014-09-08, 13:45)fritsch Wrote: [ -> ]Uninstall tvtunes.
not really a solution if it's a dependency of a skin you installed as it simply won't let you.
you would need to find it and remove manually from disk. if skin updates you would get it again.
if it's for confirming the crash i'd understand
It crashes when Python interpreter wants to run that script. So I wanted to see that bug without.
I use confluence so I don't need to have tv tunes installed.
Just disabled it and it is working perfectly again. Thanks!
