Full Version: Creating a Acestream XML channel list for p2p-streams
Hi, I am running XBMC on android and have managed to successfully get the p2p-streams addon working. I can get a good quality acestream playing by manually typing in the ace stream hash. I want to create an .xml channel list with the few streams that I want to use regularly to add into the p2p-streams addon. Can anyone help me out with the layout of the xml file to make it work? Thanks.
All the info you need can be found on the p2p streams wiki.Here`s a direct link to the `lists` section Smile
https://github.com/enen92/P2P-Streams-XBMC/wiki/Lists
