2014-09-10, 05:48
XBMC BUILD: OpenElec 4.0.7 / XBMC 13.1 Git 84725b0 (compiled Jul 9, 2014)
ISSUE: i have two paths on remote server added to the video library. The protocol used is SMB. Each path contains a subfolder with the same name (eg, smb://server/path1/folderXYZ, smb://server/path2/folderXYZ). The 'folderXYZ' will not be showed on 'Video Library/Files' screen. As soon as i change name of the folder under either 'path1' or 'path2' to smth different (eg, to 'folderABC') and rescan the library, i would see both 'folderXYZ' and 'folderABC'. So, in other words, instead of 'merging' videos from the folders into a single view, XBMC seems to be blocking the path completely. I tried removing the everything from the library and rescan from scratch with the same outcome. This used to work correctly under one of the previous builds (4.0.5 or 4.0.6).
Is this a known issue? Has this been fixed? Or it is smth wrong with my setup?
Vlad
Vlad
