Full Version: FilmOn addon Issue
I've been using an android box with XBMC on it for the last month or so but I'm having issues with the FilmOn addon.
The addon will open and work fine until it attempts to show the stream on screen and the stream is scrambled. At first I though this was to do with FilmOn login details but after configuring them, it still occurs. I can hear the volume but can't see the picture.
I've tried using FTV aswell and the same issue is occuring. However, when I've tried other streams on Navi for example, they've worked fine.
Any ideas? Thanks.
Hi - I am having the exact same issue - works on 12.3 "Frodo" just not 13.2 “Gotham”.
Did you manage to find a fix?
