Full Version: Crestron TCP or HTTP control KODI.
Hello all, my name is Juanma. Good morning from Spain.
I had a Crestron module to control XBMC, but there isn't exactly that I wanted.
So, I have time now, and I've started to read JSON 2.0 API v6. And I have several examples like this:
{"jsonrpc":"2.0","method":"Input.Select","id":1}
I've readed all "method" API, but my question is: where can I find a manual to understand the structure of that expression?
I don't know, for example, how to use params in "Audiolibrary", or why I have to put "id":1....
Sorry for my english, but I think that you will can understand me.
Please, help.
I have a loop to send this command:
{"jsonrpc": "2.0", "method": "AudioLibrary.GetAlbums","params": { "limits": { "start" : 0, "end": 10 }},"properties": ["thumbnail"],"id":1}
I can to change the value of "start" and "end" to go for all positions, but if a send this, I can not recieve the cover address.
My crestron module say me the ALBUM_ID and the label of this one but, how can I play this ALBUM_IDHuh?
There is a Crestron module available at https://code.google.com/p/kodi-crestron/
Take a look at the source code of XBMCMain.usp file to see examples of using Crestron to communicate with xbmc/Kodi
Are they the same commands using KODI?
