Full Version: <readbufferfactor>
Hi.
I wonder if you can help me.
Im using the 12.3 frodo version.
I have a question...
In advancesettings.xml settings i have a question on this otpion.
<advancedsettings>
<network>
<alwaysforcebuffer>1</alwaysforcebuffer>
<readbufferfactor>4.0</readbufferfactor>
<cachemembuffersize>0</cachemembuffersize>
</network>
</advancedsettings>
In the <readbufferfactor>4.0</readbufferfactor> witch is the correct format for the option
<readbufferfactor>4.0</readbufferfactor> or <readbufferfactor>4</readbufferfactor>
Either. It's a multiplier, so XBMC/Kodi just uses the value in an equation to figure out the buffer fill rate.
EDIT: note, this feature only works in XBMC v13 and later. It does not work in v12.
Ok.
But tell me something.
It must be like this <readbufferfactor>4.0</readbufferfactor> or <readbufferfactor>4</readbufferfactor>
Like 4.0 or only 4 Huh?
By the way, can you take a look at my advancedsettings.xml and tell me if it ok ??
<advancedsettings>
<network>
<buffermode>1</buffermode>
<alwaysforcebuffer>5</alwaysforcebuffer>
<cachemembuffersize>178257920</cachemembuffersize>
<curlclienttimeout>30</curlclienttimeout>
<limitcacherate>false</limitcacherate>
<curllowspeedtime>240</curllowspeedtime>
<curlretries>2</curlretries>
<disableipv6>true</disableipv6>
</network>
<gui>
<algorithmdirtyregions>3</algorithmdirtyregions>
<nofliptimeout>0</nofliptimeout>
<visualizedirtyregions>false</visualizedirtyregions>
</gui>
<lookandfeel>
<enablerssfeeds>false</enablerssfeeds>
<guires>720</guires>
</lookandfeel>
<video>
<latency>
<delay>0</delay>
</latency>
</video>
<videoscanner>
<ignoreerrors>true</ignoreerrors>
</videoscanner>
<videolibrary>
<cleanonupdate>true</cleanonupdate>
</videolibrary>
<imageres>720</imageres>
<fanartres>1080</fanartres>
<allowd3d9ex>true</allowd3d9ex>
<fullscreen>true</fullscreen>
</advancedsettings>
Rtfm - readbufferfactor does not work on 12/frodo.
