Let's try this again in the correct forum...
I am using a color picker to set the accent color to the string "accent.color". I have text in my skin that uses the color definition "Accent". It doesn't seem possible to set this to a string or variable (as per the wiki and personal experience). Is there a workaround I am not thinking of? This is needed in particular for labels in which I have two colors in one label (for example- movie name (white) movie year (accent) ).
you can use
<label>[COLOR white]movie title[/COLOR] [COLOR accent]movie year[/COLOR]</label>
not sure if i completely understood your question though. it would help if you would post the corresponding code snippets.
Phil,
I am moving my skin from a preset list of accent colors (themes) to using a color picker to select the accent colors. With the picker colors are set for like this-
<item id="28">
<onclick>Skin.SetString(accent.color,ffed2914)</onclick>
<onclick>Close</onclick>
<thumb>colors/FFed2914.png</thumb>
<label>FFed2914</label>
</item>
Prior to doing this, I used the code you have in your example for instances where I had two colors I one label. However since XBMC doesn't allow colors (in this case Accent) to be defined as anything but hex values in the theme XMLs so I cannot set "Accent" to equal this string. This isn't a problem is most cases as I can use <textcolor> for any text that uses the accent color for the entire label. It is the labels where I need both colors that the issue arises.
first of all you do not need pngs for every color. easier would be in your case to just use
<colordiffuse>$INFO[ListItem.Label]</colordiffuse>
on a white image in item/focussedlayout. that saves you some work.
it would not make sense to put anything "dynamic" like vars or strings into the color xmls since they should provide your "default" values for every theme.
you can use variables for example though if you want to override those default values, like
<variable name="FontColor">
<value condition="!IsEmpty(Skin.String(CustomColor))>$INFO[Skin.String(CustomColor)]</value>
<value>some_color_from_color_xml</value>
</variable>
and then
<label>[COLOR=$VAR[FontColor]]someText[/COLOR] some more Text</label>
or
<textcolor>$VAR[FontColor]</textcolor>
does that answer your question?
Gotcha. Thanks.
Second thing I noticed- it seems that although labels support variables as textcolor, textboxes do not... or am I just going crazy?
A few things-
- using colordiffuse instead of images doesn't work. The <colordiffuse> attribute doesn't seem to allow $INFO, although it does allow $VAR.
- [COLOR] has to be explicit- no variables allowed.
(2014-09-14, 16:33)ZexisStryfe Wrote: [ -> ]- using colordiffuse instead of images doesn't work. The <colordiffuse> attribute doesn't seem to allow $INFO, although it does allow $VAR.
no, both works. I´m using it.
(2014-09-14, 17:50)phil65 Wrote: [ -> ]no, both works. I´m using it.
Hrm... what version are you running on? These doesn't seem to work for me and I am running 13.2. I have tried it in several places.
For example- this is the code for the layout
<control type="image">
<left>5</left>
<top>5</top>
<width>133</width>
<height>133</height>
<texture>colors/color_white.png</texture>
</control>
Like this, I have white squares. If I add
<colordiffuse>$INFO[ListItem.Label]</colordiffuse> I get no squares.
And for reference the items look like this-
<item id="2">
<!--green 1-->
<onclick>Skin.SetString(accent.color,93ce5f)</onclick>
<label>FF93ce5f</label>
</item>
I´m running 13.2.
try Container(xx).ListItem.Label if the image is not inside focused/itemlayout.
EDIT: youre right, that does not work inside lists. I only used it outside of the list.
Well now I feel less crazy...
Now I just need to figure out what to do for my textboxes (in lists of course...).
(2014-09-15, 00:13)phil65 Wrote: [ -> ]I´m running 13.2.
Yep, doesn't work in lists. User set colours for home tiles was the primary reason why I needed to use a grouplist of buttons rather than a list container for the home menu in Eminence. It was a real pain to do....
It would be awesome if all these "quirks" with lists were resolved in Helix. Between this and the funky placement of center aligned labels it really is a pain in the butt...
Center alignment is fixed in Helix.
well, 50% there
