Full Version: TV Show season node in custom video node
I'm running Aeon MQ5 on openelec and was wondering if there was any way to force the TV season node to display while selecting shows from a custom video node in the menu. When I use the default TV Shows press menu option, selection of a series takes you to the season node, but when i use the video node linked to my tv show folder, it does not display the season node. The shows are all scraped correctly.
You mean it goes straight to epsiode level?
I use playlists instead of nodes, maybe try that instead.
