Full Version: Custom skin back up.
Hi all.. I have been playing around with the aeon nox 5 skin and am pleased with my set up.
So that I don't loose all the customisation I made which folders do I need to back up so that I can restore if needed.
Also if I wanted to port this to different machines across different platforms eg openelec, windows etc... Is it the same folders to copy over. Thanks.
Easiest way would be to rename it (folder and in the addon.xml).
Hitcher... Thanks but how do I do that?
When you say customisation do you mean you've edited the skin itself or just it's settings?
Settings. Just made some changes to the menu items . Sorry if that is basic.
Then they should not be affected when the skin upgrades but they're stored in the guisettings.xml in your userdata folder.
