2014-09-14, 18:33
Hello,
I am using this amazing sking on all my installations and i am very happy with it, but i wanted to be able to see the progress of buffering in the progress bar.
I found in this thread a solution from torenvalk that does work but the buffer bar is bigger with that code.
To display the buffer use this code instead.
Here is the code.
To add buffer bar edit DialogSeekBar.xml located in %appdata%\XBMC\addons\skin.amber\1080i
Look for and do not touch:
Immediately after insert this code:
You can change the color of buffer bar to what ever suits you by changing the Grey to lets say Blue.
Happy ambering and cudos to amber developer. Thanks a lot man. I hope you use this in a future update.
Here is the code.
<control type="progress" description="Buffer Bar">
<posx>600</posx>
<posy>3</posy>
<width>720</width>
<height>18</height>
<texturebg border="15,0,15,0">VideoOSD/ProgressBG.png</texturebg>
<midtexture border="15,0,15,0">VideoOSD/ProgressBar.png</midtexture>
<info>Player.CacheLevel</info>
<visible>Player.Caching</visible>
</control>
<control type="progress" description="Cache Progress Bar">
<posx>600</posx>
<posy>3</posy>
<width>720</width>
<height>18</height>
<colordiffuse>Grey</colordiffuse>
<info>Player.ProgressCache</info>
<visible>true</visible>
</control>
