Full Version: Advanced launcher wont work
Hello guys,
I am a noob user of spmc on my android box minix x7.
recently i discovered advanced launcher from Angelscry,infortunatly i cannot use it the correct way on my minix as there is a problem for creating launchers.xml and back up.xml,and that the script often fails.
I asked the creator on his website about this problem,and here is answer:
"Ok... I have found the problem : https://code.google.com/p/python-for-and...tail?id=35
Seems thart there is a bug with pyton language that is not able to recoginze the system encoding on Android based systems for python version lower than 2.7.2. XBMC python version is 2.6 : http://wiki.xbmc.org/index.php?title=Pyt...nt#Version
I will try to found a way to fix it... Maybe force "UTF-8" encoding if an error occurs.
And finally he says that "Sorry... but after speding long hours on the problem I'm not able to fix it by myself."
so i'm asking here,if anyone would know how to resolve the problem?
Help is much appreciated guys,hope that we can make it work
Having the same problem.
