Full Version: SMB share with Gotham 13.2 and Mavericks
Hi
Just wanted to know if there is a solution?!
I read that some people have the same issue!
If i go under files and want to add a source, i cannot chose SMB as network sharing option!
On the other hand if i go to SYSTEM and file manager (or something like that) i can add source and use SMB when browsing for a new source!
So my question?! Why can i use SMB on one hand but not on the other side??
Hmm, odd. This is the first I've heard of it working in one place but not another. Normally it's all or nothing. Can you get us a debug log (wiki) of when you try to add an SMB share in both places? That might give us some clues.
Ok. Will do this after work tonight! Thanks
Hi
Seems there was a possibility to chose SMB sharing in the files section...i just didn't notice i had to scroll down, but no mather where i want to add a source with smb i get error 2: share not available... But from prefious versions i have some videos shared through smb and they play fine... So the share must be available...
Here my log:
http://xbmclogs.com/show.php?id=294976
