Full Version: Stacked DVD-ISO-Images do not play more than first file?
Hello there,
I've been using XBMC for some time now, mostly on windows but have tried a raspberry for some time, too. Returned to Windows for performance reasons with my favourite skin.
Now, I have a multi-DVD-Image-Version of Harry Potter 7 on my NAS and XBMC (13.0 and 13.2) do play the first part, but stop after it with an error pointing to the log file.
Movies are in separate folders, names taken from imdb.
The three image-files are named equally with "CD1", "CD2" and "CD3" appended to the filenames.
XBMC correctly finds the movie, displays it as a single movie, but stops at the end of the first image-file.
I think I marked the relevant part in the log in bold letters. Anyone any idea? It's the same problem on four machines with totally different hardware (AMD/intel, AMD/AMD), though all running Win8.
18:55:14 T:1560 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:55:14 T:1560 NOTICE: -----------------------------------------------------------------------
18:55:14 T:1560 NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: x86 Win32 32-bit
18:55:14 T:1560 NOTICE: Using Release XBMC x32 build, compiled Aug 17 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
18:55:14 T:1560 NOTICE: Running on Windows 8 64-bit, build 9200
18:55:14 T:1560 NOTICE: Host CPU: AMD FX™-6300 Six-Core Processor, 6 cores available
18:55:14 T:1560 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
18:55:14 T:1560 NOTICE: Running with restricted rights
18:55:14 T:1560 NOTICE: Aero is enabled
18:55:14 T:1560 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
18:55:14 T:1560 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
18:55:14 T:1560 NOTICE: special://masterprofile/ is mapped to: C:\Users\Patrick\AppData\Roaming\XBMC\userdata
18:55:14 T:1560 NOTICE: special://home/ is mapped to: C:\Users\Patrick\AppData\Roaming\XBMC\
18:55:14 T:1560 NOTICE: special://temp/ is mapped to: C:\Users\Patrick\AppData\Roaming\XBMC\cache
18:55:14 T:1560 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
18:55:14 T:1560 NOTICE: Local hostname: Patricks_SSD2
18:55:14 T:1560 NOTICE: Log File is located: C:\Users\Patrick\AppData\Roaming\XBMC\xbmc.log
18:55:14 T:1560 NOTICE: load settings...
18:55:14 T:1560 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:55:14 T:1560 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:55:14 T:1560 NOTICE: Default DVD Player: dvdplayer
18:55:14 T:1560 NOTICE: Default Video Player: dvdplayer
18:55:14 T:1560 NOTICE: Default Audio Player: paplayer
18:55:14 T:1560 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:55:14 T:1560 NOTICE: Log level changed to 0
18:55:14 T:1560 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:55:14 T:1560 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:55:14 T:1560 NOTICE: Loaded playercorefactory configuration
18:55:14 T:1560 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:55:14 T:1560 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:55:14 T:3780 NOTICE: Thread ActiveAE start, auto delete: false
18:55:14 T:2856 NOTICE: Thread AESink start, auto delete: false
18:55:14 T:3780 NOTICE: Found 2 Lists of Devices
18:55:14 T:3780 NOTICE: Enumerated DIRECTSOUND devices:
18:55:14 T:3780 NOTICE: Device 1
18:55:14 T:3780 NOTICE: m_deviceName : {9DD2A1A6-149F-4FEF-A626-F3A4CD22C37E}
18:55:14 T:3780 NOTICE: m_displayName : SPDIF - Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_displayNameExtra: DIRECTSOUND: Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
18:55:14 T:3780 NOTICE: m_channels : FL,FR
18:55:14 T:3780 NOTICE: m_sampleRates : 44100
18:55:14 T:3780 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
18:55:14 T:3780 NOTICE: Device 2
18:55:14 T:3780 NOTICE: m_deviceName : {BA2AAC90-22B6-464E-8E25-697B98AF7ACD}
18:55:14 T:3780 NOTICE: m_displayName : Speakers - Lautsprecher (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_displayNameExtra: DIRECTSOUND: Lautsprecher (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:55:14 T:3780 NOTICE: Device 3
18:55:14 T:3780 NOTICE: m_deviceName : default
18:55:14 T:3780 NOTICE: m_displayName : default
18:55:14 T:3780 NOTICE: Device 4
18:55:14 T:3780 NOTICE: m_deviceName : {DD6C0518-08B7-44BA-BEA9-A1AFCBD1F7F4}
18:55:14 T:3780 NOTICE: m_displayName : Headphones - Kopfhörer (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_displayNameExtra: DIRECTSOUND: Kopfhörer (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: Enumerated WASAPI devices:
18:55:14 T:3780 NOTICE: m_displayNameExtra: WASAPI: Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_sampleRates : 96000,48000,44100
18:55:14 T:3780 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:55:14 T:3780 NOTICE: m_displayNameExtra: WASAPI: Lautsprecher (High Definition Audio-Gerät)
18:55:14 T:3780 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:55:14 T:3780 NOTICE: m_displayNameExtra: WASAPI: Kopfhörer (High Definition Audio-Gerät)
18:55:14 T:1560 NOTICE: Running database version Addons16
18:55:14 T:1560 NOTICE: ADDONS: Using repository repository.xbmc.org
18:55:14 T:1560 NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
18:55:14 T:4344 NOTICE: Thread PeripBusCEC start, auto delete: false
18:55:14 T:1072 NOTICE: Thread RemoteControl start, auto delete: false
18:55:14 T:6068 NOTICE: Thread PeripBusUSB start, auto delete: false
18:55:14 T:1560 NOTICE: Found screen: PnP-Monitor (Standard) on AMD Radeon HD 7800 Series (Microsoft Corporation - WDDM v1.20), adapter 0.
18:55:14 T:1560 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 640x480@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Previous line repeats 2 times.
18:55:14 T:1560 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 640x480@ 67.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 720x480@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 800x600@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1024x768@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1152x864@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x768@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x800@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x960@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x1024@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1440x900@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1440x900@ 75.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
18:55:14 T:1560 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
18:55:14 T:1560 NOTICE: Checking resolution 16
18:55:14 T:1560 NOTICE: No Joystick name specified, loading default map
18:55:14 T:1560 NOTICE: Previous line repeats 35 times.
18:55:14 T:1560 NOTICE: Running database version ViewModes6
18:55:14 T:1560 NOTICE: Running database version Textures13
18:55:14 T:1560 NOTICE: Running database version MyMusic46
18:55:14 T:1560 NOTICE: Running database version MyVideos78
18:55:14 T:1560 NOTICE: Running database version TV22
18:55:14 T:1560 NOTICE: Running database version Epg7
18:55:15 T:1560 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
18:55:15 T:1560 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:55:15 T:5500 NOTICE: Thread LanguageInvoker start, auto delete: false
18:55:15 T:1560 NOTICE: Previous line repeats 2 times.
18:55:15 T:1560 NOTICE: initialize done
18:55:15 T:4496 NOTICE: Thread LanguageInvoker start, auto delete: false
18:55:15 T:1560 NOTICE: Running the application...
18:55:15 T:5284 NOTICE: Thread JobWorker start, auto delete: true
18:55:15 T:4000 NOTICE: -->Python Interpreter Initialized<--
18:55:15 T:1560 NOTICE: ES: Starting event server
18:55:15 T:2780 NOTICE: Thread LanguageInvoker start, auto delete: false
18:55:15 T:4676 NOTICE: Thread EventServer start, auto delete: false
18:55:15 T:4676 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:55:15 T:372 NOTICE: Thread TCPServer start, auto delete: false
18:55:15 T:4676 NOTICE: UDP: Listening on port 9777
18:55:15 T:5780 NOTICE: Thread JobWorker start, auto delete: true
18:55:15 T:5500 NOTICE: Previous line repeats 1 times.
18:55:15 T:5500 NOTICE: -->Python Interpreter Initialized<--
18:55:15 T:5740 NOTICE: -->Python Interpreter Initialized<--
18:55:15 T:4496 NOTICE: -->Python Interpreter Initialized<--
18:55:15 T:2780 NOTICE: -->Python Interpreter Initialized<--
18:55:15 T:4000 NOTICE: script.grab.fanart: Grab Fanart Service Started
18:55:15 T:540 NOTICE: Thread AlarmClock start, auto delete: false
18:55:15 T:4496 NOTICE: StorageServer Module loaded RUN
18:55:15 T:4496 NOTICE: StorageClient-2.5.4 Starting server
18:55:17 T:552 NOTICE: Thread BackgroundLoader start, auto delete: false
18:55:21 T:1664 NOTICE: Thread JobWorker start, auto delete: true
18:55:23 T:2856 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:27096, P:16512, O:26440.
18:55:37 T:5788 NOTICE: Thread BackgroundLoader start, auto delete: false
18:55:45 T:5628 NOTICE: Thread LanguageInvoker start, auto delete: false
18:55:45 T:5628 NOTICE: -->Python Interpreter Initialized<--
18:57:01 T:1560 NOTICE: NFS is idle. Closing the remaining connections.
18:57:39 T:1560 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(stack) in stack://nfs://192.168.178.22/volume2/Filme/Harry Potter und die Heiligtümer des Todes - Teil 1 (2010)/Harry Potter 7-CD1.ISO , nfs://192.168.178.22/volume2/Filme/Harry Potter und die Heiligtümer des Todes - Teil 1 (2010)/Harry Potter 7-CD2.iso , nfs://192.168.178.22/volume2/Filme/Harry Potter und die Heiligtümer des Todes - Teil 1 (2010)/Harry Potter 7-CD3.iso
18:57:39 T:1560 ERROR: file_open - Could not open input
18:57:39 T:1560 NOTICE: DVDPlayer: Opening: nfs://192.168.178.22/volume2/Filme/Harry Potter und die Heiligtümer des Todes - Teil 1 (2010)/Harry Potter 7-CD1.ISO
18:57:39 T:1560 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
18:57:39 T:1560 NOTICE: DXVA::CProcessorHD:TonguereInit - The Direct3d device doesn't support DXVA-HD.
18:57:39 T:1560 NOTICE: CWinRenderer:Tonguereinit - could not init DXVA-HD processor - skipping
18:57:39 T:5216 NOTICE: Thread DVDPlayer start, auto delete: false
18:57:39 T:5216 NOTICE: Creating InputStream
18:57:39 T:5216 NOTICE: DVDPlayer: playing a file with menu's
18:57:39 T:5216 NOTICE: Creating Demuxer
18:57:39 T:5216 WARNING: could not find codec parameters for nfs://192.168.178.22/volume2/Filme/Harry Potter und die Heiligtümer des Todes - Teil 1 (2010)/Harry Potter 7-CD1.ISO
18:57:39 T:5216 NOTICE: Opening audio stream: 1 source: 512
18:57:39 T:5216 NOTICE: Opening audio stream: 0 source: 512
18:57:39 T:5216 NOTICE: Opening Subtitle stream: 0 source: 512
18:57:39 T:5216 NOTICE: Opening Subtitle stream: 1 source: 512
18:57:39 T:5216 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
18:57:39 T:5216 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
18:57:39 T:5776 NOTICE: Thread BackgroundLoader start, auto delete: false
18:57:39 T:4152 NOTICE: Thread JobWorker start, auto delete: true
18:57:39 T:5216 NOTICE: Opening video stream: 0 source: 256
18:57:39 T:5216 NOTICE: Creating video codec with codec id: 2
18:57:39 T:5216 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
18:57:39 T:5216 NOTICE: Creating video thread
18:57:39 T:5216 NOTICE: Opening audio stream: 2 source: 256
18:57:39 T:5216 NOTICE: Finding audio codec for: 86019
18:57:39 T:4484 NOTICE: Thread DVDPlayerVideo start, auto delete: false
18:57:39 T:4484 NOTICE: running thread: video_thread
18:57:39 T:5216 NOTICE: Creating audio thread
18:57:39 T:2996 NOTICE: Thread DVDPlayerAudio start, auto delete: false
18:57:39 T:2996 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
18:57:39 T:2996 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
18:57:39 T:4484 NOTICE: fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 720, dheight: 405
18:57:39 T:4484 NOTICE: Display resolution DESKTOP : 1920x1080@ 60.00 - Full Screen (16)
18:57:42 T:2996 ERROR: CDVDPlayerAudio:Big GrinecodeFrame - Decode Error. Skipping audio packet (-1)
18:57:42 T:5216 NOTICE: Opening Subtitle stream: 4 source: 256
18:57:45 T:2996 ERROR: CDVDPlayerAudio:Big GrinecodeFrame - Decode Error. Skipping audio packet (-1)
18:59:32 T:2996 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:59:32 T:4484 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
18:59:32 T:5216 NOTICE: CDVDPlayer::OnExit()
18:59:33 T:5216 NOTICE: DVDPlayer: eof, waiting for queues to empty
18:59:33 T:5216 NOTICE: DVDPlayer: closing audio stream
18:59:33 T:5216 NOTICE: Closing audio stream
18:59:33 T:5216 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
18:59:33 T:5216 NOTICE: Waiting for audio thread to exit
18:59:33 T:2996 NOTICE: thread end: CDVDPlayerAudio::OnExit()
18:59:33 T:5216 NOTICE: Closing audio device
18:59:33 T:5216 NOTICE: Deleting audio codec
18:59:33 T:5216 NOTICE: DVDPlayer: closing video stream
18:59:33 T:5216 NOTICE: Closing video stream
18:59:33 T:5216 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
18:59:33 T:5216 NOTICE: waiting for video thread to exit
18:59:33 T:4484 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
18:59:33 T:4484 NOTICE: thread end: video_thread
18:59:33 T:5216 NOTICE: deleting video codec
18:59:33 T:5216 NOTICE: DVDPlayer: closing subtitle stream
18:59:33 T:5216 NOTICE: Closing subtitle stream
18:59:33 T:5216 NOTICE: CDVDPlayer::OnExit() deleting demuxer
18:59:33 T:5216 NOTICE: CDVDPlayer::OnExit() deleting input stream
18:59:33 T:4168 NOTICE: Thread BackgroundLoader start, auto delete: false
18:59:33 T:1560 NOTICE: CDVDPlayer::CloseFile()
18:59:33 T:1560 NOTICE: DVDPlayer: waiting for threads to exit
18:59:33 T:1560 NOTICE: DVDPlayer: finished waiting
18:59:33 T:6116 NOTICE: Thread JobWorker start, auto delete: true
18:59:35 T:1560 NOTICE: Storing total System Uptime
18:59:35 T:1560 NOTICE: Saving settings
18:59:35 T:1560 NOTICE: stop all
18:59:35 T:1560 NOTICE: stop player
18:59:35 T:1560 NOTICE: ES: Stopping event server
18:59:36 T:4676 NOTICE: ES: UDP Event server stopped
18:59:36 T:1560 NOTICE: stop sap announcement listener
18:59:36 T:1560 NOTICE: clean cached files!
18:59:36 T:1560 NOTICE: unload skin
18:59:36 T:4496 NOTICE: StorageServer-2.5.4 Closed down
18:59:37 T:5740 WARNING: CPythonInvoker(2, C:\Users\Patrick\AppData\Roaming\XBMC\addons\service.library.data.provider\service.py): the python script "C:\Users\Patrick\AppData\Roaming\XBMC\addons\service.library.data.provider\service.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class XBMCAddon::xbmcgui::Window
18:59:37 T:1560 NOTICE: stopped
18:59:37 T:1560 NOTICE: destroy
18:59:37 T:1560 NOTICE: closing down remote control service
18:59:37 T:1560 NOTICE: unload sections
18:59:37 T:1560 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:59:37 T:1560 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
18:59:37 T:1560 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
18:59:37 T:1560 NOTICE: application stopped...
Put them all in the same folder, remove the file stacking. And please remove your log from your post and use pastebin next time.
Thanks for answering. Sadly I'm as dumb as before now.
What's pastebin? I intended to put the log into Spoiler-Brackets, but this forum does not seem to support this common php-command.
They are in the same folder, which is named according to IMDB. How can I remove stacking? And when I achieve that: I understood that stacking is the way to go to make XBMC play several files as if it were one?
