Hi everybody,
is it with the FTV and XBMC (Vu+ Addon) possible to stream LIVE TV (SAT)?
As long as you have a Vu+ box, then it should in theory:
VUPlus (wiki)
Yes, i have one. But didn't a FTV and cant test the theorie.
So i hope anyone already test ist...
There's mixed reports about the Fire TV's ability to decode MPEG2 videos, which is most likely what you will get on most live TV setups. Some people say the Fire TV is hardware decoding MPEG2, which means it should work fine even for HD videos. Some can't get it to work, which means MPEG2 in HD will likely stutter.
Thank you.
which then means I probably have to wait until someone reports who had tried it.
