2014-10-17, 13:00
Nonsense. Provide us with the details I have requested you provide (debug log and curl --version), or you're just trolling. You don't have curl 7.38 if you're using OpenELEC.
(2014-11-25, 01:10)coreymc Wrote: [ -> ]How can this be?
(2014-11-25, 01:25)coreymc Wrote: [ -> ]post 41 of this thread say's it was fixed in openelec 4.2.1
7:32:55 T:140285350758144 NOTICE: Thread EventServer start, auto delete: false
17:32:55 T:140285350758144 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:32:55 T:140285350758144 NOTICE: UDP: Listening on port 9777
17:32:55 T:140287219763136 ERROR: JSONRPC Server: Failed to connect to sdpd
17:32:55 T:140285308794624 NOTICE: Thread TCPServer start, auto delete: false
17:32:55 T:140285283616512 NOTICE: Thread JobWorker start, auto delete: true
17:32:55 T:140287219574528 NOTICE: Thread RSSReader start, auto delete: false
17:32:55 T:140285292009216 NOTICE: Thread AirPlayServer start, auto delete: false
17:32:55 T:140286223173376 NOTICE: -->Python Interpreter Initialized<--
17:32:55 T:140286413768448 NOTICE: -->Python Interpreter Initialized<--
17:32:55 T:140287219574528 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
17:32:55 T:140287219574528 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
17:32:55 T:140286231566080 NOTICE: -->Python Interpreter Initialized<--
17:32:55 T:140285694695168 NOTICE: -->Python Interpreter Initialized<--
17:32:55 T:140286402283264 NOTICE: RCB Service: Start
17:32:55 T:140286402283264 NOTICE: RCB Service: launch RCB on startup = false
17:32:55 T:140286402283264 NOTICE: RCB Service: scrape games on startup = false
17:32:55 T:140286402283264 NOTICE: RCB Service: Done
17:32:55 T:140285261170432 NOTICE: AxelProxy Downloader Starting - 127.0.0.1:45550
17:32:55 T:140285261170432 NOTICE: Press CTL break to stop.....
17:32:55 T:140286206387968 NOTICE: -->Python Interpreter Initialized<--
17:32:55 T:140287219574528 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
17:32:55 T:140286197995264 NOTICE: -->Python Interpreter Initialized<--
17:32:55 T:140285694695168 NOTICE: [TVonline] Subscription service starting...
17:32:55 T:140286214780672 NOTICE: StorageServer Module loaded RUN
17:32:55 T:140286214780672 NOTICE: StorageClient-2.5.4 Starting server
17:32:55 T:140286197995264 NOTICE: 17:32:55 T:140286197995264 NOTICE: 1Channel: Loading sqlite3 as DB engine
17:32:55 T:140286197995264 NOTICE: Previous line repeats 1 times.
17:32:55 T:140286197995264 NOTICE: 1Channel: Building PrimeWire Database
17:32:55 T:140286197995264 NOTICE: PrimeWire: Service: Resetting...
17:32:55 T:140286197995264 NOTICE: PrimeWire: Service starting...
17:32:56 T:140287219574528 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
17:32:56 T:140287219574528 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
17:32:56 T:140287219574528 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
17:32:56 T:140285179995904 WARNING: CreateLoader - Unsupported protocol(library) in library://video/movies/poster.jpg
17:32:56 T:140285179995904 WARNING: CreateLoader - Unsupported protocol(library) in library://video/movies/poster.png
17:32:56 T:140285179995904 WARNING: CreateLoader - Unsupported protocol(library) in library://video/movies/banner.jpg
(2014-12-02, 19:19)Komerad Wrote: [ -> ]The error seems different but I believe curl is the bad guy here. Can someone confirm?
(2014-12-04, 20:03)kevins7189 Wrote: [ -> ]Based on what was said in the thread, I downgraded curl/libcurl to 7.32.0-3 and the issue went away. So is this a more widespread issue?
