2014-09-20, 02:34
I recently installed PseudoTV Live and I noticed that my xbmc got muted. I tried to use another add on, but there was no audio. I'm wondering is there anyway I can get the sound back without reinstalling xbmc.
(2014-09-20, 02:34)topclass Wrote: [ -> ]I recently installed PseudoTV Live and I noticed that my xbmc got muted. I tried to use another add on, but there was no audio. I'm wondering is there anyway I can get the sound back without reinstalling xbmc.
Quote:I created a slightly modified package of XBMC/Kodi for the Fire TV
(2015-12-09, 15:30)David1977 Wrote: [ -> ]maybe you should ask at XDA developers or at least create your own thread and don't hijack others threads .I don't want to hijack others threads, I want to combine same topics into one thread instead of many threads with the same topic
(2015-12-09, 15:30)David1977 Wrote: [ -> ]reading from your first link: "elmerohueso from xda" : http://forum.xda-developers.com/showthre...?t=2790392Sadly, I understand that.
I see:
So it seems he changed something. If he changes something, he should support it, I guess. So, no offense, but my suggestion is, that it's hard to get support for something "not-official" as Team-Kodi has it's own APK:
http://kodi.tv/download/
(2015-12-09, 15:30)David1977 Wrote: [ -> ]For the joystick support....I grepped my own guisettings.xml and found this:Thx, this is a soltution I can try, next time when I am at the same place like the stikc
<enablejoystick default="true">true</enablejoystick>
So as a wild guess:
<enablejoystick default="true">false</enablejoystick>
will do the trick
(2015-11-15, 22:19)someotherguy Wrote: [ -> ]I had something similar, but immediately after installation of KODI (sound always muted).
Using the fire tv android app, simply press the "+" key in the keyboard screen. Sound comes on immediately. I can't believe this worked, but I tried all of the other solutions from other forums without luck.
