2006-06-13, 09:42
hey everyone, i'm having major problems loading up xbmc and not i need some help. everything was running fine and in installed the 666 build and at first it worked great. i noticed that after a while it failed to work and gave me a fatal error that it was unable to load strings.xml.
a fresh installed fixed the problem but after a power off and a power on it always gave me the error again.
now i installed the build from 6/11 and i have yet to be able to get into xbmc.
i've cleared everything from all folders and the app is being launched from evox to rule out the shortcut problems.
the only thing wrong with my xbox is the dvd rom drive is failing but i can't imagine why that is causing the problem.
here is my log... any help would be greatly appreciated as i'm out of options.
Quote:00:35:10 m: 53075968 notice: -----------------------------------------------------------------------
00:35:10 m: 53055488 notice: starting xboxmediacenter. built on jun 12 2006
00:35:10 m: 53055488 notice: q is mapped to: harddisk0\partition6\apps\xbmc
00:35:10 m: 53055488 notice: log file is located: q:\xbmc.log
00:35:10 m: 53055488 notice: -----------------------------------------------------------------------
00:35:10 m: 53055488 notice: setup directx
00:35:11 m: 53030912 notice: load settings...
00:35:11 m: 53030912 notice: loading q:\userdata\guisettings.xml
00:35:11 m: 52871168 notice: getting hardware information now...
00:35:11 m: 52871168 notice: checking resolution 10
00:35:11 m: 52871168 notice: setting autoresolution mode 4
00:35:11 m: 52981760 notice: loading q:\xboxmediacenter.xml
00:35:15 m: 49418240 error: unable to load q:\language\english\strings.xml: failed to open file at line 0
00:35:16 m: 49418240 warning: emergency recovery console starting...
00:35:16 m: 49954816 fatal: xbmc fatal error:
00:35:17 m: 49954816 fatal: q:\language\english\strings.xml, line 0
00:35:17 m: 49954816 fatal: failed to open file
00:35:17 m: 49954816 fatal: init network using dash settings...
00:35:17 m: 49954816 warning: use dashboard
00:35:19 m: 49639424 fatal: ip address: 192.168.0.5
00:35:19 m: 49639424 fatal: starting ftp server...
00:35:19 m: 47534080 fatal: ftp server running on port 21, login: xbox/xbox
