hello guys & gals
Im trying to get an m3u playlist to work on xbmc that i have made with 10 channels. i have tried everything and it will not work using simple pvr. i pasted some channels to pastebin and set it to raw and added the link in simplepvr and it just gives me an empty list. i downloaded it to android and same thing just an empty list. any help please thnx.
Read a guide on how to create the playlist file properly, there are probably hundreds of examples on the forum. And you can't use just "youtube.com" as a channel.
(2014-09-22, 11:52)negge Wrote: [ -> ]Read a guide on how to create the playlist file properly, there are probably hundreds of examples on the forum. And you can't use just "youtube.com" as a channel.
hahaha that was an example "youtube"
anyway i installed windows on a machine and it all worked fine
now im pissed because i cant use windows, only linux. its something to do with a driver on my machine it locks up when i enable live tv the xbmc freezes solid and i have to then killall -9 xbmc.bin it. i hate android so now im stuck testing on 2 thing i hate until i solve this lock up issue with linux running gotham 13.2
on windows 7 it shows after i reboot xbmc right away 1748 channels have loaded, on linux and android it shows nothing so ...
maybe i could use a plugin and read it from my dreambox iks server ? i will keep reading.
B̒̅͋͗̄̎̄ͮͬ̏͡҉̵̶̴̦̹̤̬͖̱̯i͗̒̀ͤ͆́͐̂̈͌̇҉̀͏̞͙͖̳̱̳̫̭́t̖͙͕̝͍͔̻͔̲̲͙̜̏ͣ͌ͫ̿͋ͮͭ͒͛̔́̋̀ͥ̊̀͘͜͞͞c̴̡͇̤̣̰͔̟̟̯̓̅ͣͥ̇̍͝͠h̝͎̲̼͎̗̤̹͔͈̠̦̜ͣ͛̍͐ͩͥͯ̿̅̈̈͛̾ͯ̏͆͡͞͞e̷͍͙̘̥̰̹̘̮͍͕͉̰̗̯͕͔͊̄̂͆ͣ͗̏̈ͩ̂̄ͭͫͨ̍̎̔́͢ͅͅs̢̧͖̻͉͓͇̭͇̟̹̭̮͍ͪ̅̌̑͛ͣͣ͒͂̎́ͭ́̿͠ ͣͪͤ̇̉̂͆ͦ̚҉̸̵̹͇͚̖͚̻̼̲̩̖͕̥̪̲̞̱̯̩͞d̴̵̷̪̟̺̝͎̥̞̪̗̂͑̆̑̒̓̒̚͝o̴̷̳̞̝̻ͦ̌́͋ͩͧͯ̕͢͝ͅn̴͙͚̝̤͊̍͊ͥͤͥ̔͊̾ͥͯ̂ͣ̉̌ͣ̂̀̚͞'̞̳̦̙̹̱̝͉̰̥̤̱̻̹̙̰̀̍ͥ͂͆͊͌̔ͭ̑ͯͤ̾͑ͤͨ̒̋́͘͟t̷̫͈̣̘͉̻̮̣̘̖̙͔͆̈̒̈́̂ͫ̀͘͘͝ͅ ̉̽͒̂ͫͦ̍̉͂ͩ̇ͥ̚͠҉̧͓̫̫͓̝͚̳̭̱̠̠̣͔̞̺͍̙̠͞kͨ͆͛̈́ͪ́̚҉̶͕̩̜ņ̶̩̪̹͍̫̟̰̝̟̪̮̪̖͍̦͂͊̄̓͒̓ͩ͒͐ͥ̎͗̇ͥ͋̾́͢ộ̗̘̬̥͚͎͖̬̙̯͓̗͔̥̲͖ͦͤͯ́͘͠w̘͚̩̹̫̻̻ͥ̂͛̀̃̽̉ͯ̉ͯͮ͢͢͢ ̰͈̟̘̮͆̀̓ͭ̒͒͛͆̌͒̒̍ͤ͗͞͝͠ā̧̩͚̻̥̺̖͙͓͍̝̣͎̦̥̼̯͍͚̎̽͐̆̓ͣ̌̒͛͘̕b̨̠͖͇̯̻͙̣̣̞̮̫͍̲̰̼̀̔͐ͥ̈͗͐ͪ̒ͫ̎ͪ̆ͬ̓ͩͦ̍͟͟͡ͅͅo̷̷͈̫̤̱͓ͫ̄͑͗̿̾ͦ̿͗́͛̕͟͠ͅṷ̵̢͖͍̬̫̖̯͍̼̰̦̹̹͕̟̳ͧ̽̉ͪͧ̿̓ͬͫ͑ͫ̅̌̑̚͜t̷̰̩̲̹̪̮̙̘̞̮͓̙͖͖̬ͪ̈́ͪ͝ͅ ̢̺̥͈͚͚̞̗̩͚̾ͩ̋ͧ̑͑͛͂͌̔͆̾ͣ̕͠͞m̶̗̻̯͕̜̦̘̒ͣ̉͊͌̑ͧ̉ͣ̓̀́͟͡yͮ̑̄̌̕҉̜̳̺̭̩̯͎̻̠ ̘͎̹̥̩̭̻͖̞̭͎͗́̂̐́́ͥ̇̇̓͆̆́̕͢͟p̸̧̳̣͙̺̖͖̫͉̤̭̺̖̪̲̮̉̀̆̍́́̚̚̚͢o̸̢̤͇̻̟̪̖̳̠̺͚̗̝̝͖͒ͫ͊̈̅̽̌͐͌ͨͫ̃̎̚͘k̸̙̗͔͈̳̝͙̹̩̻̈̊̅͐ͯ͒̀ͭͬé̸ͭͬ͑ͥ̇͋͑͂͂̆̆̆͛̅̀̚͟͝҉̦̫̭̼̦̭ͅm̴̖͕̝͎̣͙̫͖̺̝͕̭̬͔͊̊ͮ̽̒̿̆̏̚ͅo̢̢̯̯͔͚̖͓̣̬̯̭̘̠͈̙͖ͮ͑̾̓̀̽͗̋̀͂ͣ̃ͪ͆̽͂ͮ͠n̷͎̙̟̟̥̗̯̭̘̻͕̤̹̞͍̭͔̔͐́̔ͪ̏ͬ͊ͨ͌ͥ̀̕
