Full Version: Best TV Box for under £70.00
Hi there,
New to XBMC TV boxes, so looking for some advice.
I would like to spend no more than £70.00. Need a TV Box that comes pre-loaded with XBMC. It also needs to come pre-loaded with some add-ons.
I just want to use box for films, mainly HD and TV shows that I can hopefully stream, unsure exactly what add-ons that I require to achieve these two things.
If someone could please recommend a TV box that has latest software installed that you think would successfully do the job that would be great. If you could also send a link, so I can purchase that would be perfect. Happy to purchase off any website, ebay/amazon etc, or anything else you suggest.
Thank you so much.
Jamie
