Full Version: central database with different versions
Hello everybody
i have a raspbmc and a openelec installation on my system in two different rooms.
i do also have a centralized nas.
top awsomeness would be to use a single centralized SQLITE file on that centralized harddrive. is that possible?
an alternative could be a online mysql database, and the last alternative would be a local mysql setup.
so, what could i do? is it a problem that the two rasp have different distributions? (but both on frodo)
thanks
best regards
Igor
sqlite can't be shared.
mysql sounds like the best solution. You may be able to run it on your nas.
Mixing openelec/raspbmc should be fine if they are both on same version.
thanks! is a online mysql ok too? or does it have to be on the same lan?
(2014-09-22, 16:18)sharkyenergy Wrote: [ -> ]thanks! is a online mysql ok too? or does it have to be on the same lan?
I have no experience of mysql not being on the same lan. I imagine it would slow it down somewhat.
