Full Version: Overlap fo the sub title fix posititon
Gotham 13.2 and T! SVN 6.0.6
As Confluence doesn't offer subtitle positioning in the OSD video calibration field, I'm wondering if this is a T! oversight in that i seems to be possible to lose the positing tool at the top end, and get stuck with subtitles1/3 up the screen.
This is a link to the issue at hand. http://forum.xbmc.org/newreply.php?tid=2...rocessed=1
yeah, it's a bit tricky when using a mouse.
if you use a remote control / keyboard, there should not be a problem though.
i'll make the subtitle positioning item a bit wider, so it'll be easier to grab when it's on top of the rectangle.
