Full Version: [OLD] PseudoLibrary - Strm Generator w/ Library Integration: AMAZON/HULU/NETFLIX
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
I have gotten everything I tried to work except the ustvvod plugin. Anybody found a way for that one, I am missing something silly I guess.
(2014-10-22, 20:24)cordfree Wrote: [ -> ]I have gotten everything I tried to work except the ustvvod plugin. Anybody found a way for that one, I am missing something silly I guess.
Sorry, USTVVOD has a poorly formed directory structure... I've tried on multiple occasions to engage the developers to address this problem, with no luck Sad
Maybe you can convince them? who know...
Hey, can you share some of your configs for ones that worked. I have had no luck. Did you get F.T.V to work?
Does anyone have a config that works for funnier moments? Cartoon HD? I would like to add all of the streams from these source, if possible.
I have tried the following:
TVShows|Plugin|plugin.video.cartoonHD|""|20|1|""
TVShows|Plugin|plugin.video.funniermoments|""|20|1|""
but it doesn't generate any strm's
@Lunatixz:
PseudoLib is functioning real well here except from on a little thing. Every time I open Kodi Gotham, 20 segs. or so by, it gives a script.pseudoLibrary failed error. I have set up to update the library every 6 hours. Here is a simple log that only opens Kodi, wait for the error and then shutdown Kodi.
Kodi Log
I found the error in about line 1224
Look like this :
15:56:41 T:15352   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.ValueError'>
                                            Error Contents: time data '' does not match format '%Y-%m-%d %H:%M:%S'
                                              File "C:\Users\rnieves\AppData\Roaming\XBMC\addons\script.pseudo.library\service.py", line 93, in <module>
                                                AutomaticUpdate()
                                              File "C:\Users\rnieves\AppData\Roaming\XBMC\addons\script.pseudo.library\service.py", line 63, in AutomaticUpdate
                                                Update_Timer_LastRun = datetime.datetime.strptime(Update_Timer_LastRun, '%Y-%m-%d %H:%M:%S')
                                              File "C:\Program Files\XBMC\system\python\Lib\_strptime.py", line 325, in _strptime
                                                (data_string, format))
                                            ValueError: time data '' does not match format '%Y-%m-%d %H:%M:%S'
Looks like it is a date formating error.
Can you please take a look at this. I already iron the EPG for F.T.V using mc2xml and a task. it is set for Eastern Time ( I had no luck with ftvguide.xml, seems it is not downloading any programming), and although F.T.V. streams are much or less stable some of them change every 3 or 4 days (Al Jazeera and Euro News the must frequent) so this is the final piece of my setup. Thanks.
(2014-10-27, 23:48)Fallito Wrote: [ -> ]@Lunatixz:
Kodi Log
Look like this :
                                                AutomaticUpdate()
Looks like it is a Dte Formating error.
Can you please take a look at this. I already iron the EPG for F.T.V using mc2xml and a task for Eastern Time ( I had no luck with ftvguide.xml, seems it is not downloading any programming), and although F.T.V. streams are much or less stable some of them change every 3 or 4 days (Al Jazeera and Euro News the must frequent) so this is the final piece of my setup. Thanks.
Yeah, I know about some issues... going to push an update soon...
(2014-10-27, 05:06)tenchu98 Wrote: [ -> ]Does anyone have a config that works for funnier moments? Cartoon HD? I would like to add all of the streams from these source, if possible.
You have to use Generic type if you're in the root. Remember there are TVShows and Movies in there.
(2014-10-27, 23:52)Lunatixz Wrote: [ -> ]
Kodi Log
Look like this :
                                                AutomaticUpdate()
Thanks, Lunatixz. Kudos for all this great work!
V.0.0.7 Pushed to repo, Includes Service fix, SMB strm paths, misc tweaks...
Confirmed working nicely.
(2014-10-28, 00:38)Fallito Wrote: [ -> ]
I tried changing it to Generic, and the progress box blinks onto the screen and nothing happens.
I just want it to generate strm files for all links in the plugins. I was hoping to be able to do this for multiple addons.
I love the concept of this addon, just wish it could integrate into kodi and add the 'add to library' option to every context menu. I have always thought that it should be an integral part of xbmc/kodi.
Now if I can just get it to generate some strm's
Here's an icon idea for your addon: Image
<a href="http://tinypic.com?ref=jfeyoj" target="_blank"><img src="http://i61.tinypic.com/jfeyoj.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
(2014-10-28, 16:36)tenchu98 Wrote: [ -> ]
Does this work at the root level for other addons? Have you tried specifying a subfolder?
(2014-10-28, 20:56)spyder Wrote: [ -> ]
(2014-10-28, 00:38)Fallito Wrote: [ -> ]You have to use Generic type if you're in the root. Remember there are TVShows and Movies in there.
Yes, it works at root level, just don't add a folder to the configuration, ie plugin://plugin.video/vevo
Thanks for pushing the update, but I still have fails.
1. addon: mxrte
Generic|Plugin|plugin.video.mxrte|""|25|1|""
Log: https://dl.dropboxusercontent.com/u/8532...rte%20.log
2. addon mxbbc log:
Generic|Plugin|plugin.video.mxbbc|""|25|1|""
Log: https://dl.dropboxusercontent.com/u/8532...0mxbbc.log
In both examples I am able to see the data to be written to the .strm file inside the log, but it fails to create the file. I have extracted the data and hard coded, but I would like to run it every day so I have up-to-date streams.
