Full Version: TV Shows being added, but not showing
I'n new to the XBMC scene. I added my movies without problems, but when the time came to add the TV Shows, it shows nothing in the library. This is a short extract of the XBMC log,:
08:25:19 T:8008 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
08:25:19 T:9684 NOTICE: VideoInfoScanner: Starting scan ..
08:25:19 T:9684 DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
08:25:19 T:9684 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanStarted
08:25:19 T:9684 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'F:\TV Shows\Afro Samurai\'
08:25:19 T:9684 DEBUG: ADDON::CScraper::FindMovie: Searching for 'Afro Samurai' using The TVDB scraper (path: 'C:\Program Files (x86)\XBMC\addons\metadata.tvdb.com', content: 'tvshows', version: '1.5.4')
08:25:19 T:9684 DEBUG: scraper: CreateSearchUrl returned <url cache="cache-Afro%20Samurai.xml">http://thetvdb.com/api/GetSeries.php?seriesname=Afro%20Samurai&amp;language=en</url>
08:25:19 T:9684 DEBUG: Using proxy srvgmfw01.gmsantacruz.gov.bo:8089, type 0
08:25:19 T:9684 DEBUG: CurlFile::Open(0A040DD8) http://thetvdb.com/api/GetSeries.php?ser...anguage=en
08:25:19 T:9684 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://thetvdb.com
08:25:19 T:8008 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
08:25:21 T:9684 DEBUG: CScraperUrl::Get: Using "UTF-8" charset for XML "http://thetvdb.com/api/GetSeries.php?seriesname=Afro%20Samurai&language=en"
08:25:21 T:9684 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results><entity><title>Afro Samurai</title><language>en</language><url cache="79755-en.xml">http://thetvdb.com/api/1D62F2F90030C444/series/79755/all/en.zip</url><id>79755</id></entity></results>
08:25:21 T:9684 DEBUG: ADDON::CScraper::GetVideoDetails: Reading movie 'http://thetvdb.com/api/1D62F2F90030C444/series/79755/all/en.zip' using The TVDB scraper (file: 'C:\Program Files (x86)\XBMC\addons\metadata.tvdb.com', content: 'tvshows', version: '1.5.4')
08:25:21 T:9684 DEBUG: Using proxy srvgmfw01.gmsantacruz.gov.bo:8089, type 0
08:25:21 T:9684 DEBUG: CurlFile::Open(0A040DD8) http://thetvdb.com/api/1D62F2F90030C444/...all/en.zip
08:25:22 T:9684 DEBUG: CScraperUrl::Get: Using "UTF-8" charset for HTML "http://thetvdb.com/api/1D62F2F90030C444/series/79755/all/en.zip"
08:25:22 T:9684 DEBUG: scraper: GetDetails returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><details><id>79755</id><fanart url="http://thetvdb.com/banners/"></fanart><episodeguide><url cache="79755-en.xml">http://thetvdb.com/api/1D62F2F90030C444/series/79755/all/en.zip</url></episodeguide></details>
08:25:22 T:9684 DEBUG: VideoInfoScanner: Adding new item to tvshows:F:\TV Shows\Afro Samurai\
08:25:22 T:9684 DEBUG: CAnnouncementManager - Announcement: OnUpdate from xbmc
08:25:22 T:9684 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnUpdate
08:25:22 T:9684 DEBUG: VideoInfoScanner: Found episode match F:\TV Shows\Afro Samurai\afro_1x01.avi (s1e1) [[\._ \[\-\\/]([0-9]+)x([0-9]+)([^\\/]*)(?Sad?:[\\/]video_ts)[\\/]video_ts.ifo)?]
08:25:22 T:9684 DEBUG: VideoInfoScanner: Found episode match F:\TV Shows\Afro Samurai\afro_1x02.avi (s1e2) [[\._ \[\-\\/]([0-9]+)x([0-9]+)([^\\/]*)(?Sad?:[\\/]video_ts)[\\/]video_ts.ifo)?]
08:25:22 T:9684 DEBUG: VideoInfoScanner: Found episode match F:\TV Shows\Afro Samurai\afro_1x03.avi (s1e3) [[\._ \[\-\\/]([0-9]+)x([0-9]+)([^\\/]*)(?Sad?:[\\/]video_ts)[\\/]video_ts.ifo)?]
08:25:22 T:9684 DEBUG: VideoInfoScanner: Found episode match F:\TV Shows\Afro Samurai\afro_1x04.avi (s1e4) [[\._ \[\-\\/]([0-9]+)x([0-9]+)([^\\/]*)(?Sad?:[\\/]video_ts)[\\/]video_ts.ifo)?]
08:25:22 T:9684 DEBUG: VideoInfoScanner: Found episode match F:\TV Shows\Afro Samurai\afro_1x05.avi (s1e5) [[\._ \[\-\\/]([0-9]+)x([0-9]+)([^\\/]*)(?Sad?:[\\/]video_ts)[\\/]video_ts.ifo)?]
08:25:22 T:9684 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'F:\TV Shows\Afro Samurai\afro_1x01.avi'
08:25:22 T:9684 DEBUG: ADDON::CScraper::GetEpisodeList: Searching 'http://thetvdb.com/api/1D62F2F90030C444/series/79755/all/en.zip' using The TVDB scraper (file: 'C:\Program Files (x86)\XBMC\addons\metadata.tvdb.com', content: 'tvshows', version: '1.5.4')
08:25:22 T:9684 DEBUG: scraper: GetEpisodeList returned <episodeguide></episodeguide>
08:25:22 T:9684 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:03
Everything seems to be fine, but my library is still empty. I'm doing something wrong? The name convention seems fine, and even the episodes are being detected.
Welcome.
Check your naming - I suspect 'Afro Samurai 1x01.avi' would work, but 'afro_1x01.avi' won't.
Welcome to forums.
And in addition to the info you been given see Naming_video_files/TV_shows (wiki) also using tools like Filebot (wiki) increase the change of doing it right naming and not just "whatever"
Please avoid posting logs inline and also avoid posting log portions, use a pastebin and pastebin the full logs in future please. Just link that pastebin link here.
Acording to http://wiki.xbmc.org/index.php?title=Nam...s/TV_shows, you can use one of this naming schemes:
With season
The most common scenario.
anything_s01e02.ext (1)
anything_s1e2.ext (1)
anything_s01.e02.ext (1)
anything_s01_e02.ext (1)
anything_1x02.ext (5)
anything_102.ext (6)
are you suggesting I should use this:
anything(space)s01e01.ext ??
I used the space instead of the underscore, still no luck. Here is the log of the last attempt:
http://pastebin.com/xq9Z6MNQ
Your advancedsettings.xml modifications are messing up the matches. Try changing it to
<tvshowmatching action="append">
