Full Version: Can't Add TV or Movies source at all??
Hi all,
Just installed Kodi on a brand new PC, but I can't get it to add any TV or Movie sources?
When I go to the Set Content for the folders where you usually set TV or Movies etc. all I get is the following text...
?0? and ?-1?
Can anyone help? its driving me crazy.
Dave
Here's a screenshot of the problem...
https://imageshack.us/i/eyL6MBSej
Try using the default skin. If you are using "Kodi" then you're probably using v14 alphas, which has changed a lot of stuff for other skins, thus labels might be broken.
(2014-09-27, 16:57)Ned Scott Wrote: [ -> ]Try using the default skin. If you are using "Kodi" then you're probably using v14 alphas, which has changed a lot of stuff for other skins, thus labels might be broken.
Perfect!! changed to the default skin and we're up and running....thank you so much, never thought to try that at all.
Thanks again
Dave
