Full Version: my XBMC is gone to f**k
Hey Guys
I'm running the latest version of Gotham on the Ouya.
Over the last couple of weeks its all gone Pete Tong.
'Script Failed' from many of the what used to be most reliable depositories.. (Movreel & Sockshare)
Now though, I seem to be getting script failed and awful lot.. Not just for the above two.. But for most of the different sources.. Gorillavid... Mooshare... AllMyVideos..
Any ideas?
Ask the script providers.
I used Ouya for a few months and traded it in for an OpenElec Chromebox. It's infinitely better. Double the price, but less frustration.
My Ouya reset and lost all it's settings 3 times. My addons never worked well. The videos froze all the time. ....all the time.............
So far, I've been pretty pumped with my Chromebox. 6 months in and works great. It freezes up MAYBE once per month, and only after I've done a bunch. I just get up and reset it. It's back up in like 8 seconds. Ouya took 2 minutes.
If you plan to store a bunch natively (apps and settings and backups), you may want to increase the internal space. I haven't yet, but I did run out once. Easy fix with a few small setting changes.
Just an fyi...
