Thanks Jin will give it a try a bit later.
Thanks JinJin. V1.4 now working. Grabbed v1.7 too
Hi JinJin - thanks for your work on the Eurosport Player, I was using it fine on my Fire Stick until a few weeks ago but have recently encountered some problems. To try and solve the problems I upgraded to Kodi 17.1 and the player still won't load (it wouldn't on the previous version of Kodi either). I was using the eurosport player version 16.0 and also just tried the new 17.0. Log files are here if that helps. Thanks in advance.
http://paste.ubuntu.com/24170887/
Is the website eurosportplayer.com working for you?
The addon can not get your geoloaction. Are you using a vpn or similar?
You're right! I was using a Smart DNS service. I just checked it and the settings needed updating. It's now working again. Thanks for the quick response
Hi JinJin,
Still having some problems with the Firestick this evening. Kodi 17.1 is running and version 17.0 of your player but I can't seem to load streams. Have checked Smart DNS is working and also that Eurosport Player Website functions correctly. Any ideas based on the log file? Cheers
http://paste.ubuntu.com/24176896/
First of all thank you so much for this amazing addon.
I have same error than jamest2017 ("ERROR: OpenDemuxStream - Error creating demuxer") on Rpi 2 with openelec 7.0.1 and kodi 16.1 jarvis, but this error raise only when i try look long videos on demand (about 30min). If i try look short videos (2 or 3 min) all work perfect, and channels works perfectly too. All work perfect on kodi 17 on my windows computer.
ps : sorry if my english is bad
jamest2017
Please upload a log with debug log enabled.
Avigeilpro
Sorry but to get replays working you'll have to update to kodi 17 (Libreelec).
(2017-03-14, 20:56)JinJin Wrote: [ -> ]Sorry but to get replays working you'll have to update to kodi 17 (Libreelec).
That's what i thought, anyway thank you for the addon and for the support
Well, ffmpeg cant load the stream for whatever reason.
This is at least not an addon problem and since you're using smartdns i cant really help here.
Can you test it without dns or kodi 16? Sorry to say but you're kinda on your own.
Hi JinJin, downgrading to Kodi 16.1 and running version 17 of Eurosport has worked. Thanks for the tips
Hi JinJin, been using your Eurosport Addon for a while and currently working well but have a request (or a brief explanation of how i could fix)?
I have my Kodi device physically connected thru an inline VPN router.
Addon Language/Geolocation settings seem to default to the country currently being used to route traffic.
(e.g. can only get german channels so have to unplug and run through main router to get UK channels/language)
"def set_location(self)" possibly requests these defaults in the "client.py" file?
Any chance of a country/language picker to override this in the addon settings page or .......
... a simple code edit that i can apply just to lock down to EN_GB?
Nope sorry, use an uk ip?!
Also for others,
if you're using vpn or smartdns services you are on your own. There will be no support from my side.
