2014-10-03, 06:34
Pages: 1 2
2014-10-03, 16:55
Unlikely, there isn't even an official logo artwork to put in there. I heard a rumour after the 11/12 Of October the logo portion will be announced and then its up to whoever manages the existing code to update it the Plymouth splash, which will unlikely take place in the official side before Kodi v14 is shipped in the Kodibuntu.
In any case I haven't heard of any unofficial Plymouth related jobs + kodi..
2014-10-03, 19:24
Thought so, using latest nightly - everything says kodi except for the splash
2014-10-03, 20:20
The bootsplash will be available some time soon. Watch this space.
Please test the below.
Courtesy of fritsch
cd to some directory you have r/rw privs.
and to install
or
Courtesy of fritsch
wget https://dl.dropboxusercontent.com/u/55728161/plkodi/kodibuntu-plymouth-theme_0.1.0%7Etrusty1_all.deb
wget https://dl.dropboxusercontent.com/u/55728161/plkodi/plymouth-theme-kodibuntu-logo_0.1.0%7Etrusty1_all.deb
wget https://dl.dropboxusercontent.com/u/55728161/plkodi/plymouth-theme-kodibuntu-text_0.1.0%7Etrusty1_all.deb
and to install
sudo dpkg -i filename.deb
or
sudo dpkg -i *.deb
2014-10-03, 20:25
Important: This is nothing official at all - I was just bored of my Intel system constantly crashing :-) for exactly 2 minutes.
Build for trusty without any intention to make a nice artwork - just shown how it can be done. PR is welcome to: https://github.com/xbmc/XBMCbuntu/tree/m...buntu-logo
mkdir pls
cd pls
wget https://dl.dropboxusercontent.com/u/55728161/plkodi/kodibuntu-plymouth-theme_0.1.0%7Etrusty1_all.deb https://dl.dropboxusercontent.com/u/55728161/plkodi/plymouth-theme-kodibuntu-logo_0.1.0%7Etrusty1_all.deb https://dl.dropboxusercontent.com/u/55728161/plkodi/plymouth-theme-kodibuntu-text_0.1.0%7Etrusty1_all.deb
sudo dpkg -i *deb
2014-10-04, 07:58
Works great, looks fine to me - cheers
2014-11-24, 20:48
Bumped to subscribe (now that there's an official logo).
2014-12-05, 09:55
I have updated eXcyle's xbmc plymouth splash with the new Kodi logo that is available on the wiki:
https://dl.dropboxusercontent.com/u/2241...i-logo.deb
2014-12-05, 23:28
(2014-12-05, 09:55)teeedubb Wrote: [ -> ]I have updated eXcyle's xbmc plymouth splash with the new Kodi logo that is available on the wiki:
Nice, thanks Deeedubb!
2015-01-02, 09:22
Does this replace the XBMCBuntu splash screen?
2015-01-02, 09:47
(2015-01-02, 09:22)suku_patel_22 Wrote: [ -> ]Does this replace the XBMCBuntu splash screen?
Yes
2015-01-02, 10:34
2015-02-09, 20:37
I tried KODIbuntu on a different machine, it has a sweet animated logo. Is it possible to update XBMCbuntu with the same boot animation? Although I wonder if my NUC would even have time to display it since it boots so fast.
2015-02-21, 06:32
2015-07-15, 07:34
The new animated version of this is in GitHub.
I downloaded it today and compiled it for replacing on my xbmcbuntu.
https://www.dropbox.com/s/udso4dhckjasfs...l.deb?dl=0
Now I had an issue installing this, errors about
I ran this to correct
Then the animated boot up and shutdown worked perfectly.
# sudo dpkg -i plymouth-theme-kodibuntu-animated-logo_0.45-1_all.deb
Quote:grep: /boot/config-3.14.2-amdfixes5+: No such file or directoryWhich caused my Plymouth updates only to work on shutdown not boot up. I think I came from installing the earlier packages posted above, not sure.
WARNING: missing /lib/modules/3.14.2-amdfixes5+
Device driver support needs thus be built-in linux image!
depmod: ERROR: could not open directory /lib/modules/3.14.2-amdfixes5+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_RVN51c/lib/modules/3.14.2-amdfixes5+/modules.order: No such file or directory
depmod: WARNING: could not open /tmp/mkinitramfs_RVN51c/lib/modules/3.14.2-amdfixes5+/modules.builtin: No such file or directory
# sudo update-initramfs -d -k 3.14.2-amdfixes5+
update-initramfs: Deleting /boot/initrd.img-3.14.2-amdfixes5+
# sudo update-initramfs -u
update-initramfs: Generating /boot/initrd.img-3.13.0-24-generic
Pages: 1 2
