2014-10-03, 14:44
I'm trying to play the stream on this page via a strm file: http://www.cybc.com.cy/en/index.php/tv?id=90
I'm a novice with Wireshark but I extracted this: cdn.webvideocore.net/live4uk/out_dqgyqc45pzk8c4gw40o4/8258850000.ts (add an http:// in front of the above stream)
Haven't encountered a .ts stream before (MPEG2?) but it wont play, I'm using the latest Gotham stable release 13.2 Git: 201140817 for Windows 7 Pro 64-bit. I've also tested on a fresh install of Gotham and still nothing ...
This is a new version of the stream which seems to have appeared over the last couple of months. Prior to this I was succesfully using an RTMP I had previously extracted via Wireshark which now doesn't seem to be available. The old version stream was as below which I can't see it in wireshark any longer, only the TS stream.
rtmp://cdn106nl.webvideocore.net:1935/pull playpath=epfeao2vff48kskgs4wk swfURL=http://play.streamingvideoprovider.com/player3.swf live=true pageUrl=http://www.cybc.com.cy/index.php/tv?id=90
Logfile output relating to the TS stream:
13:07:41 T:1780 NOTICE: Thread GUIDialogCache start, auto delete: true
13:07:41 T:6828 NOTICE: DVDPlayer: Opening: http://cdn.webvideocore.net/live4uk/out_...8850000.ts
13:07:41 T:6828 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
13:07:41 T:6828 NOTICE: DXVA::CProcessorHD:reInit - The Direct3d device doesn't support DXVA-HD.
13:07:41 T:6828 NOTICE: CWinRenderer:reinit - could not init DXVA-HD processor - skipping
13:07:41 T:6956 NOTICE: Thread DVDPlayer start, auto delete: false
13:07:41 T:6956 NOTICE: Creating InputStream
13:07:41 T:6956 ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
13:07:41 T:6956 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
13:07:41 T:6956 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
13:07:41 T:6956 ERROR: XFILE::CFileCache::Open - failed to open source <http://cdn.webvideocore.net/live4uk/out_dqgyqc45pzk8c4gw40o4/8258850000.ts>
13:07:41 T:6956 ERROR: CDVDPlayer::OpenInputStream - error opening [http://cdn.webvideocore.net/live4uk/out_...8850000.ts]
13:07:41 T:6956 NOTICE: CDVDPlayer::OnExit()
13:07:41 T:6956 NOTICE: CDVDPlayer::OnExit() deleting input stream
13:07:41 T:6828 ERROR: Playlist Player: skipping unplayable item: 0, path [http://cdn.webvideocore.net/live4uk/out_...8850000.ts]
13:07:41 T:6828 NOTICE: CDVDPlayer::CloseFile()
13:07:41 T:6828 NOTICE: DVDPlayer: waiting for threads to exit
13:07:41 T:6828 NOTICE: DVDPlayer: finished waiting
- Should this TS play ok via a strm file or are there some other parameters I need to sniff out?
- Can anyone shed any light on the log errors above, eg, "ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)"
Many thanks in advance for any clues!
