(2014-10-26, 15:27)knuti Wrote: [ -> ]If I go to Live-TV, now I can see all of my movies (which are on hdd,hdd1,hdd2 of the solo2) in one big list, I have information about the movies (comes from the solo2, not from the XBMC,I think),
You're right. These meta-data belong to your VU STB.
Quote: I do not see any posters/fanart/covers corresponding to the movie, instead I see a picon of the channel I once made the recording from. I don´t see any option for a scraper in Live-TV, so I have to accept the things as they are...
You can't use a Scraper in the "Vu plus addon", btw. it wouldn't make sense.
Quote:If I go to "Videos/Dateien/movies solo2 hd" (I use the TMDb-scraper here), I see the following...
The scraper is running, but no info/poster/fanart/covers at all...I think there is something wrong with the filenames.
There's nothing wrong with the filenames, the Enigma2 OS names its recordings in a different way (Date-Channel-Titel.ts).
But you can change that easily for upcoming recordings, just change the setting of "Composition of the recording filenames" from "standard" to "short without date" (see the attached screenshot).
You will find that menu item (on your STB) in "main menu"-"setup"-"system"-"customize" on the 2nd page.
A recording like "20140613 2200 - Sky Cinema HD - Broken City.ts" should be named now as "Broken City.ts" and such filenames are working with XBMC scrapers.
For your existing recordings: Start the (standard) movieplayer or EMC of your VUplus STB and rename your old recordings (movielist-menu button-rename).
I prefer the following procedure:
I store all recordings in the file path "media / hdd /movie". If I want to keep a movie, I move it to "media / hdd / movie / movies".
I add "media / hdd / movie / movies" to XBMC via "Videos"-"Files"-"Add Videos" and select "Movies" with the Scraper "The Movie Database" (you can use "Universal Movie Scraper" instead).
Now all my movies are available from the XBMC main menu item "Movies", inclluding all Fanarts, posters, metadata and so on.
If you want to archive your television series accordingly, you have to proceed differently, f.i.:
I've created subfolders for each TV show:
media/hdd/movie/series = main folder
--- Defiance = subfolder
--- GameofThrones = subfolder
The subfolder Defiance contains filenames like:
"Defiance_s02e09.ts" = Defiance Season 2, Episode 9
or ...
"Defiance_s02e11.ts" = Defiance Season 2, Episode 11
The result should look like that:
For further information according to naming conventions of TV Shows you should take a look at
Kodi WIKI.
I hope that helps you a bit, but you should be aware that i'm quite a beginner in XBMC issues.
And don't worry about your English skills, I'm from Austria.
I know your nickname from the german "Vuplus-support forum", feel free to contact me, if you like.
Cheers, lizard!
