2014-10-07, 16:35
I've been trying to troubleshoot an issue I've been having with a "new" computer I got and installed OpenELEC on. I have 4 computers with OpenELEC and only the new one is behaving this way. It seems to go into hibernation mode at some point and I can't wake it up. I thought it happened whenever I didn't touch it for a while, but the more I think about it and test it over time, I think it only happens when I leave it on pause. Basically when I come back my TV is black and the remote or keyboard doesn't have any effect. I have to hold down the PC's power button and power it back on.
Here's a snippet from the log I looked at from the last time it happenned:
I'm not sure what to make of this. The last thing that was logged was that it activated the screen saver.
09:51:41 T:2788162368 NOTICE: Previous line repeats 3 times.
09:51:41 T:2788162368 NOTICE: Thread BackgroundLoader start, auto delete: false
09:51:43 T:2788162368 NOTICE: Thread JobWorker start, auto delete: true
09:51:43 T:2992487232 NOTICE: Thread RSSReader start, auto delete: false
09:51:43 T:2630314816 NOTICE: Thread JobWorker start, auto delete: true
09:51:55 T:3032627968 NOTICE: Log level changed to 2
09:51:55 T:3032627968 NOTICE: Enabled debug logging due to GUI setting. Level 2.
09:51:55 T:3032627968 DEBUG: ------ Window Init () ------
09:51:55 T:3032627968 DEBUG: LIRC: Update - NEW at 44778113:160 0 KEY_OK_UP devinput (KEY_OK_UP)
09:51:56 T:3032627968 DEBUG: LIRC: Update - NEW at 44778946:e2 0 KEY_MEDIA devinput (KEY_MEDIA)
09:51:56 T:3032627968 DEBUG: OnKey: percent (0x25) pressed, action is PreviousMenu
09:51:56 T:3032627968 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
09:51:56 T:3032627968 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
09:51:56 T:3032627968 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
09:51:56 T:3032627968 DEBUG: ------ Window Init (Settings.xml) ------
09:51:56 T:3032627968 DEBUG: LIRC: Update - NEW at 44779314:e2 0 KEY_MEDIA_UP devinput (KEY_MEDIA_UP)
09:51:56 T:3032627968 DEBUG: LIRC: Update - NEW at 44779515:e2 0 KEY_MEDIA devinput (KEY_MEDIA)
09:51:57 T:3032627968 DEBUG: ------ Window Deinit (Settings.xml) ------
09:51:57 T:3032627968 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
09:51:57 T:3032627968 DEBUG: ------ Window Init (Home.xml) ------
09:51:57 T:2788162368 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
09:51:57 T:2788162368 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
09:51:57 T:2788162368 DEBUG: GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
09:51:57 T:2788162368 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
09:51:57 T:2788162368 DEBUG: RunQuery took 3 ms for 10 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
09:51:57 T:2788162368 DEBUG: RunQuery took 2 ms for 10 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
09:51:57 T:2788162368 DEBUG: RunQuery took 1 ms for 0 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
09:51:57 T:2788162368 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
09:51:57 T:3032627968 DEBUG: LIRC: Update - NEW at 44779904:e2 0 KEY_MEDIA_UP devinput (KEY_MEDIA_UP)
09:51:58 T:3032627968 DEBUG: LIRC: Update - NEW at 44781561:189 0 KEY_VIDEO devinput (KEY_VIDEO)
09:51:58 T:3032627968 DEBUG: OnKey: 7 (0x07) pressed, action is fullscreen
09:51:58 T:3032627968 DEBUG: Activating window ID: 12005
09:51:58 T:3032627968 DEBUG: ------ Window Deinit (Home.xml) ------
09:51:58 T:3032627968 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
09:51:58 T:3032627968 DEBUG: GL: Vertex Shader compilation log:
09:51:58 T:3032627968 DEBUG: GL: Vertex Shader compiled successfully
09:51:58 T:3032627968 DEBUG: GL: Pixel Shader compilation log:
09:51:58 T:3032627968 DEBUG: GL: Fragment Shader compiled successfully
09:51:59 T:3032627968 DEBUG: LIRC: Update - NEW at 44781984:189 0 KEY_VIDEO_UP devinput (KEY_VIDEO_UP)
09:51:59 T:3032627968 DEBUG: LIRC: Update - NEW at 44782360:cf 0 KEY_PLAY devinput (KEY_PLAY)
09:51:59 T:3032627968 DEBUG: OnKey: 234 (0xea) pressed, action is Play
09:51:59 T:3032627968 DEBUG: CAnnouncementManager - Announcement: OnPause from xbmc
09:51:59 T:3032627968 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPause
09:51:59 T:3032627968 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
09:52:00 T:3032627968 DEBUG: LIRC: Update - NEW at 44782743:cf 0 KEY_PLAY_UP devinput (KEY_PLAY_UP)
09:52:14 T:3032627968 INFO: CheckIdle - Closing session to http://feeds.openelec.tv (easy=0xa46c4fa0, multi=0xaec2cac8)
09:52:14 T:3032627968 INFO: CheckIdle - Closing session to http://feeds.xbmc.org (easy=0xa46da470, multi=0xa1ae6160)
09:52:27 T:2630314816 DEBUG: Thread JobWorker 2630314816 terminating (autodelete)
09:52:27 T:2788162368 DEBUG: Thread JobWorker 2788162368 terminating (autodelete)
09:55:00 T:3032627968 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
09:55:00 T:3032627968 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
09:55:00 T:3032627968 DEBUG: ------ Window Init () ------
