2014-10-08, 01:16
Hey Guys -
I'm trying to get XBMC/Kodi set up on my Nvidia Shield Tablet. The tablet runs KitKat, has 16gb of internal storage, plus I have added a 64gb microSD card to it. I've tried probably 15 different iterations of advancedsettings.xml, but simply can't get it to work! Below are the details for what I've tried. First, though, a few specs about the device:
Device Specs
- Nvidia Shield Tablet
- Android Version: 4.4.2
- Build Number: KOT49H.24526_447.6867
- Path to userdata: "/storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/userdata
- Path to Target Folder I Created on SD Card: "/storage/sdcard1/xmbc" (Empty)
What I've Tried
I created an "advancedsettings.xml" file in the userdata folder (alongside the other primary xml files.) When I've said I've tried different things, I mean that I've edited the file in different ways to try to get it to work. Each time I try something new, I force close XBMC, reopen it, add a new source, and check to see if it's writing files in the new target folder on the SD Card.
I know that XBMC is seeing "advancedsettings.xml" as it's log file (attached) shows the redirection at the beginning.
Below are the last two I've tried without luck...
#1 - I created the folders for the <to> path beforehand. When I add a new source, the thumbnails are grabbed and shown in XBMC, but the target folder I designated below is empty.
#2 - Same as above, but I read to remove the Substitute tags as there's a bug. Same results
When running the last one above, the log said it loaded, but no go. Below's a snippet of the full log which may be downloaded here.
#3 - Different Source Path
I've also tried using "/storage/emulated/0/Android/data/org.xbmc.xbmc/.xbmc/files/userdata" instead of "special://masterprofile/" - Same results
One more quick question...
While researching this, I've found many who redirect the Thumbnails to an SMB share over the network. My library is huge and I know it would take a lot of space. Am I right to assume that using the SD card will still be much faster than a share - even if using N over 5Ghz? Know if you can browse and use XBMC while thumbnails are loading or must you wait for all to load first?
Thanks Guys!
Device Specs
What I've Tried
<advancedsettings>
<pathsubstitution>
<substitute>
<from>special://masterprofile/Thumbnails</from>
<to>/storage/sdcard1/.xbmc/userdata/Thumbnails</to>
</substitute>
</pathsubstitution>
</advancedsettings>
<advancedsettings>
<pathsubstitution>
</pathsubstitution>
</advancedsettings>
No settings file to load (special://xbmc/system/advancedsettings.xml)
Loaded settings file from special://profile/advancedsettings.xml
Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<pathsubstitution>
<to>/storage/sdcard1/.xbmc/userdata/Thubnails</to>
</pathsubstitution>
</advancedsettings>
DEBUG: Configuring path substitutions
Thanks Guys!
