Full Version: [Review] Unboxing of MXQ S85
MXQ S85 Android media player powered by Amlogic S805 quad core processor with 1GB RAM, 8GB internal storage, and Ethernet/Wi-Fi/Bluetooth connectivity. MXQ S85 looks very similar to EM6Q-MXQ, another Amlogic S805 based Android STB, which I reviewed last week, but these are two distinct hardware platforms. Today, I’ll take some pictures of the devices, and the board to see which components are used, and who made the board, and I’ll write a full review in a few days.
Gear Best currently sells MXQ S85. There are two versions: one without Bluetooth use coupon MXQCM at $45.99 http://goo.gl/AE4f9I, and one with Bluetooth use coupon MXQBCM at $47.99 http://goo.gl/MQfa5W
MXQ S85 Pictures
I’ve received the parcel via DHL in the nameless package below where they just indicate it’s and Android TV box with a quad core processor, quad core GPU, pre-loaded with XBMC, and supporting HEVC / H.265
The package contains the box, HDMI and AV cables, an OTG adapter, a 5V/2A power supply, an IR remote requiring two AAA batteries, and a user’s manual in English. The company also included a US plug adapter outside the product package.
One quick way to differentiate between MXQ S85 and EM6Q-MXQ is the MX test on top of a red band that’s specific to MXQ Q85.
There’s a power button right on the center on the top of the enclosure. On one side, we’ll find a micro SD card slot, a micro USB OTG port, as well two USB 2.0 ports, and on the rear panel, we can see the DC power jack, the AV output (composite + stereo audio), an Ethernet port, and HDMI port, and optical S/PDIF.
If you prefer an unboxing video, here it is.
MXQ S85 Board Pictures
There aren’t any screws on the outside of the case, so you need to use a flat-head precision screwdriver to pop-up the bottom of the enclosure.
The sticker make it clear it’s yet another board made by Shenzhen Netxeon Technology, and that the board features on Amlogic S805 with 1GB RAM, 8GB storage, and AP6210 Wi-Fi module. There are also some though holes that could be interesting,. But let’s remote four screws to completely take the board out of the case.
Contrary to EM6Q-MXQ, there aren’t any metallic plate inside the enclosure so the box is much lighter, and we’ll have to see if it has any consequence with regards to power dissipation. There’s no heatsink either, but instead a gray sticker, which I peeled and put on the left side in the picture. The board is named S85_V2.0_20140716, and definitely made by Netxeon… Beside the S805 processor, two MIRA P3P4GF4BLF DDR3 chips, and a 8GB 29F64G08CBABA NAND flash are soldered on the board. We can also confirm AP6210 is indeed the Wi-Fi module (2.4GHz) chosen for this product. Some of my readers bought TV110 media player, also powered by Amlogic S805, and they are now unable to flash an updated firmware since there is no recovery button, but luckily S85 does feature one just at the back of the AV output jack. There are also three unconnected header including one that looks like a JTAG header, and the one of the two 4-pin headers must be used to access the serial console.
via cnx-software
Hi and thanks for the review
I was just wondering if you had tested the CEC features at all? I got it to connect to my TV and it will work for some time, but than my TV will stop seeing it as a device.
If I reset the setting on the mxq the TV will connect again. I had recently done the firmware upgrade off the geekbuying site so I'm not sure if its what caused the instability.
