2014-10-10, 12:52
2014-10-10, 21:30
I have no idea what Frodo 19 is, but if you are using XBMC v12, which is known as Frodo, then you probably won't get much help as that version is no longer supported. In any case, I would ask Aeon Nox-specific questions here: http://forum.xbmc.org/forumdisplay.php?fid=142
2014-10-11, 14:46
(2014-10-10, 21:30)Ned Scott Wrote: [ -> ]I have no idea what Frodo 19 is, but if you are using XBMC v12, which is known as Frodo, then you probably won't get much help as that version is no longer supported. In any case, I would ask Aeon Nox-specific questions here: http://forum.xbmc.org/forumdisplay.php?fid=142
Ned, see this thread
http://forum.xbmc.org/showthread.php?tid=141714
maybe you can fix it to work on android device also
Refael.
2014-10-11, 15:41
aaah, I see, Frodo19 is a user. Still, I would ask about this in the Aeon Nox subforum.
