Full Version: List of Skins with Touch Support
Hello, all. I decided to download and test all of the default skins that currently ship with XBMC 13.2 Git:20140817-0f3db05 (Compiled: Aug 17 2014). I tested these skins on a Samsung Galaxy Tab S 8.4 (SM-T700). Here are the results of my testing:
These skins have full touch support:
  • Confluence
  • Ace
  • Aeon Nox
  • Amber
  • Black Glass Nova
  • Cirrus Extended
  • Eminence
  • Maximinimalism
  • Metroid
  • Nebula
  • Neon
  • Quartz 4
  • Rapier
  • re-Touched (no PVR support)
  • reFocus
These skins have limited touch support:
  • Backrow (Settings don't scroll)
  • Metropolis (Works but with some areas that are broken)
  • Titan MediaBrowser (Semi-functional)
  • Transparency
  • Xperience1080 (Works but is kludgy)
These skins have no touch support:
  • Aeon MQ 5
  • Bello
  • Conq
  • Hybrid
  • xTV-SAF
These skins are currently listed as "incompatible" so I was unable to test
  • Charmichael
  • diffuse
  • Droid
  • nbox
  • PM3.HD
  • Simplicity
  • Xeebo
  • Xperience More
After all of my testing, I have found Amber and reFocus the best to use for my Android tablet. Eminence is very nice as well.
Update: the criteria for my testing was simple. The skin has to respond to basic touch selections. If I touched a selection and it did not respond, the skin was marked as incompatible. In instances where I could make some selections but other basic functionality was comprised such as being able to scroll through a library, I marked the skin as partially compatible. If a skin is marked as incompatible in 13.2 settings, I was unable to test.
Here's another skin with full touch support and is very good and I use on my tabs
Confluence Customizable Mod
Also have a look at CO2touch / Carbon skin.
Care to explain why XeeBo, a fully mouse supported skin, isn't touch compatible?
Also see related discussion here http://forum.xbmc.org/showthread.php?tid=206205
(2014-10-12, 11:49)Hitcher Wrote: [ -> ]Care to explain why XeeBo, a fully mouse supported skin, isn't touch compatible?
Hi Hitcher. That skin is marked as incompatible in 13.2 so I was unable to test it.
(2014-10-12, 10:51)RockerC Wrote: [ -> ]Please update and add to the wiki http://wiki.xbmc.org/?title=Comparison_of_skin_features
I was just granted access to the wiki. I'll update that shortly.
Done!
